If u have my setup would u get a 3 wire oxygen sensor?
Old Apr 1, 2002 | 06:26 PM
vortech305's Avatar
When i first ran my car for the fist couple of months it seem like it was running little rich. As of now im using the regular Bosch Oxygen Sensor, Since the sensor is located on the header is it best to get a 3 wire sensor? or should i just stay with the single bosch one?
Old Apr 1, 2002 | 09:57 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I still have a single wire one on my car. I haven't had any problems with it but a heated one would likely get the car into closed loop a bit quicker when it is cold.
And thinking and knowing that your car is running rich are two different things. Get a scantool on it and check the BLM and INT figures to find out how it is running.
Old Apr 2, 2002 | 02:03 PM
vortech305's Avatar
thanx
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
nuggie
Aug 25, 2015 01:27 PM
squiggy2
Aug 9, 2015 09:30 PM
