hooker cat back
Old Apr 4, 2002 | 08:42 PM
fahq's Avatar
hooker cat back
What Muffler is used with the Hooker Super Comp Exaust systems and how does it sound.
Old Apr 4, 2002 | 09:03 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
Muffler used: Aerochamber...
Sound created: priceless....
There are some things money can't buy, for everything else, there's mastercard.....
Old Apr 4, 2002 | 09:07 PM
fahq's Avatar
Is it loud. I have stock Exhaust right now.
Old Apr 4, 2002 | 11:41 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Yeah it's loud, of course headers will help a lot too. If you want for some reason the sound clip in my sign hasn't been working, if you have AIM I can send it to you thru that or email.
LET'S SEE IF THIS WORKS
http://briefcase.yahoo.com/bc/buffsh...view=l&.last=1
Old Apr 5, 2002 | 05:27 PM
fahq's Avatar
fahq6969@hotmail.com
Do you still have your cat-converter?
Is the Super Comp Dual Exit or single exit and what pipe Diameter do they use?
Old Apr 5, 2002 | 07:00 PM
Car: 99 Formula
Axle/Gears: 342
I have a replacement non- hi-flo cat. They're all 3" piping. And dual exit. These are the tips that come with it.
Old Apr 6, 2002 | 02:09 PM
fahq's Avatar
How hard was the kit to install? Did you have to do any modificatons. I ordered a kit and I am going to put it on monday.
Old Apr 6, 2002 | 02:35 PM
Hg's Avatar
Hg
Car: '87 Z
He had to have a shop weld it on, he bought the cheaper system. The HO/and normal systems only difference is the way they hook up to the cat, so Mark had to have it welded since he got the one with the wrong hook up.
Old Apr 6, 2002 | 03:13 PM
fahq's Avatar
I ordered the HO one with the flange on it.
Old Apr 6, 2002 | 03:15 PM
Car: 99 Formula
Axle/Gears: 342
Yeah, what Hg said. I got the $200 one and had a square flange on it. I had the exhaust shop cut it off and weld it to the cat. Other than that it fits perfect.
Old Apr 6, 2002 | 03:51 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
hey mark
does you panard bar in the rear hit the intermediate pipe. it is 3 inch pipe right. i have 2 1/2 inch exhaust and it looks like the panard bar hit it once or twice.
Old Apr 6, 2002 | 04:02 PM
Hg's Avatar
Hg
Car: '87 Z
heavy_chevy29: I have a flowmaster 3 inch I pipe and no problems here...
Old Apr 6, 2002 | 04:29 PM
Car: 99 Formula
Axle/Gears: 342
This really shows my stupidity, what's a panard bar, but I don't hear any hitting or anything.
And actually before I use to bottom out over speed bumps, but now with the cat-back I don't.
Old Apr 6, 2002 | 05:16 PM
Hg's Avatar
Hg
Car: '87 Z
Mark: It's a bar that goes across the rear end, it's stamped steel. If you get up under your car, look for a small bar going across. You should be able to twist it fairly easily by hand: That's how bad the stock one is. It's like GM just pulled it out of the crapper and threw it on there. It holds the rear end centered. There was someone on here that shattered theirs into 3 pieces - twice. It's kinda hard to explain where it is... I can't find a pic of it either.
Old Apr 7, 2002 | 09:50 PM
fahq's Avatar
I just got done putting on the exhaust. It sounds good. I have a question about the installation. What did you do about the bracket on the passenger side that holds the muffler up?
Old Apr 7, 2002 | 10:05 PM
Car: 99 Formula
Axle/Gears: 342
I believe the exhaust shop welded a hanger on.
Old Apr 8, 2002 | 02:07 AM
IROCZ88's Avatar
The panhard bar (sometimes referred to as the track bar) is attached from the rear to the frame. All it does is prevent the rear from moving side to side. If you put an adjustable one on you can change the roll-center and improve your handling.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
drathaar907
Aug 6, 2015 04:20 PM
