muffler in place of the cats
Old Apr 9, 2002 | 12:01 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
would this mess up the flow of the exhaust. I would like to replace my cats with a muffler then run the exhaust out the back with tips.
Has anyone done this? Will the muffler be to close to the headers for it to flow right? or will the pipe from the muffler back be to long?
Old Apr 10, 2002 | 12:26 AM
HrdRockA4305's Avatar
As long as its a good flowing unit and is small enough to fit into the space ok, I don't see why it wouldn't work.
Old Apr 10, 2002 | 03:04 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
People with duals do it, why not with a single.
Old Apr 10, 2002 | 09:31 AM
IROCZ88's Avatar
Thats not a bad idea. I wonder what it would sound like with a 40 series 2 chamber flowmaster.
Old Apr 10, 2002 | 10:13 AM
Matt86Z's Avatar
I'm running a 3" shorty Dynomax where my cat was, all 3" from the headers to the pipes. It sounds way different than stock, but very agressive and nice.
Old Apr 10, 2002 | 10:56 AM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
I've seen someone do this with their dual setup. Basiclly you run two pipes down the side the exhaust is stock and have one muffler where the cat is on one pipe and then a little farther down the line put the other muffler on the second pipe so ther can both fit. Then run the pipes straight back and you will have plenty of room when you get to the back. There is not much room right there so you'll have to use small diameter mufflers.
Another idea I had was running a "69 chambered exhaust" kind of setup replacing chambers with mufflers and running them side by side. Both ways would be limited by muffler size so selection may be slim.
-Matt
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
PurelyPMD
May 5, 2016 04:57 PM
Tarizza
Sep 24, 2015 12:57 PM
cstrobel65
Sep 16, 2015 11:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
