what are some good long tube headers for 3rd gens?
Old Apr 9, 2002 | 02:46 PM
chevy power's Avatar
i want some longtube headers for my 91, what companies out there make coated longtube ones that fit 3rd gens? what is eveyone run'n, need some advice, gonna buy some soon.
Old Apr 9, 2002 | 04:21 PM
Momar's Avatar
hooker
Old Apr 9, 2002 | 04:31 PM
Fast3rdGen's Avatar
hooker is the only way to go. i got uncoated ones but they rule anyways.
Old Apr 9, 2002 | 08:53 PM
x5finger's Avatar
You can get a set of hedman full lengths for 100 $, but I hear there are fit problems with manual trannies. Stands to reason that hooker could have the same problems.
Old Apr 9, 2002 | 10:45 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
The part number for the Hooker longtubes is 2210. $385.95 at Summit. The coated ones are $579.95. Here's the part number at summit:
Uncoated- 520-2210
Coated- 520-2210-1
The main clearance problem with the hooker on a manual tranny is the slave cylinder. You should be able to move the bracket, or you can bend the headers a little. As for the hedman's I'm not sure, but on their site it says something about "floorboard modifications".
Hope that helped.
-Kyle
Old Apr 10, 2002 | 07:19 AM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
I have the Hooker Long Tubes and you don't need to modify anything to get 'em in. No floorboard modification. They fit great and they don't have trouble on T-5 cars cuz I helped put a set on in a T5 car. They're NOT emmissions legal headers though, and you will have to make your own exhaust system (at least the Y-pipe) to complete the exhaust. But these pretty much are the best long tube headers out for thirdgens and I love the sound I get with these bad boys :-).
Old Apr 10, 2002 | 08:25 PM
cool, so for the y-pipe no one sells one that will work? u just custom bent ur own tubing or what? since they aren't emissions legal then they don't have an sensors on em do they, so what do u do about the sensors that were hooked up?
Old Apr 10, 2002 | 08:38 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
How's the ground clearance on these? Any other problems to worry about?
Old Apr 10, 2002 | 09:46 PM
ChevyLuva3's Avatar
How bout SLP? I heard they were the best for thirdgens. I was thinking of Hooker or Hedman. Hooker cuz I've heard they're good. Hedman cuz theyre cheap, and seem to fit, due to there shorty style. I personally don't wanna spend any more than 400 dollars on the headers themselves, anything more is insane! Even though my rich friends, buy 600 dollar catback exhausts, not even the headers!!
Old Apr 10, 2002 | 09:56 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
SLP only makes shorties
Old Apr 11, 2002 | 07:01 AM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
My exhaust system is completely custom, nothing store bought. I had bought the sections of pipe needed, welded where I needed to weld, and ran it where it looks almost stock again. My ground clearance isn't an issue, but I have a moddeds rear suspension and k-member that hange lower than the exhaust...So my exhaust will be the last thing to scrape lol. Otherwise I don't think the ground clearance would be too bad. If you do your own custom exhaust, you should be able to figure out how to run it effectively where it won't touch the ground on a bump.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
InfinityShade
Aug 22, 2015 08:00 PM
reiderz iroc
Aug 13, 2015 04:57 PM
