Firebird headlight support bracket
The plastic piece that is bolted to the car and that the headlight bucket mounts too. One of the mounts for the headlight bucket broke. Passenger side. I don't need the headlight bucket.
Engine: 350 4 boltmain goodwrench crate
Transmission: 350 turbo 3 speed
Axle/Gears: i belive its a 323 gear ratio posi
Re: Firebird headlight support bracket
hi , ive got 2 whole assembelies off a 85 firebird , in good shape one has the headlight motor still attached , their like a bronze color ,i can get you pics sometime this weekend ,an what year car do you need them for? an ide take 30 plus s&h for them
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
the crack is shiny ... never seen plastic crack and it be shiny LOL ... bet it's aluminum .. just take it to an aluminum welder and they will fix ya right up
Nope its plastic and it is off an 87 Trans Am, thanks but I don't think the 85's are the same. I might have one from someone else lined up, if so I will let you guys know. Thanks.
Can't be plastic cause I had one break like that many years ago and I had it welded.
Wow do I feel like a moron.
I guess just cause it was painted black like all the plastics under there I assumed.... but you are right it is in fact aluminum! Good news is that my brother in law is a welder and will do it for me as a favor.
I guess just cause it was painted black like all the plastics under there I assumed.... but you are right it is in fact aluminum! Good news is that my brother in law is a welder and will do it for me as a favor. Trending Topics
You know, I finally got around to getting my brother-in-law that bracket and he said that once he scraped some of the paint off to weld it he found out it was not aluminum, but a cheap pot-metal which he says he can't weld. Looks like I am back to needing this part or will have to use some high-strength adhesive.
go to another welder because mine broke there and they welded it without a problem.
Car: 1987 Pontiac Trans Am
Engine: 5.0L
I have the driver and passenger headlights and the whole assemblies out of my '87 Trans Am. If I can help, I will send a pic to make sure it is what you need and we can make a deal. Just let me know!
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Apr 14, 2016 08:52 PM
Genopsyde
Nov 11, 2015 10:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
