[WV] Radiator supports/fan shroud
Car: 85 Camaro Z28
Engine: 400 SBC .040 over bore
Transmission: TH350 (TH400 on the way)
Ok I don't need the actual fan shroud. What I need is the piece that runs across the top of the fan shroud as the upper radiator support. I have an aftermarket direct fit kit radiator/dual electric fans/wiring from Be Cool. I just need to get it mounted more securely in the car (right now clothes hangars have it held in place for the purpose of just firing the car. Not exactly safe to actually drive.)
Car: 91 ws6
Engine: Carb'd 334 stroker
Car: 1988 Camaro
Re: Radiator supports/fan shroud
I have a few. I will check cond. and get you pictures tomorrow.
Car: 85 Camaro Z28
My fans are mounted securely to the radiator. I need the upper bracket for mounting the radiator in the car. If you can send a pic, I'll know for sure. I'm definitely interested if it's the correct part.
Car: 85 Camaro Z28
Car: 85 Camaro Z28
Attachment 299527
Is this your card? I only found these two from a quick search, the piece that goes over the rad itself, both are different sizes.. Lemmie see if I can find a matching one.
trackbird
10-28-2016 08:19 PM
LB9GTA
07-10-2016 10:46 PM
GreatDaneGTP
Exterior Parts Wanted
01-26-2016 06:12 PM
