door weather strip
Car: 92 z28
Engine: 5.7
Transmission: t56 6-speed
Axle/Gears: 3:42
door weather strip
is there some one that makes the door weather stripping with the plastic insert at the end of the seal like the original one? I have replaced them with the oer brand and the top hole where the screw goes in is tearing
Re: door weather strip
Fairchild indsutries ............ https://fairchildindustries.com/automotive/
Yes, their door seals have the molded insert. If you need ANY weatherstripping for a Thirdgen and Fairchild makes it,... it will be the best fit and quality compared to anything other than original GM parts.
I've bought Fairchild door seals thru JC Whitney ( more than once ) and got them a bit cheaper than other suppliers by using coupons/discounts. They are far superior quality over other aftermarket brands like Metro or SoftSeal.
These door seals are the most accurate reproductions on the market. These are sold as a pair and ready to install. We recommend using weather strip adhesive to assist the seal pins during installation.
Features:
Lifetime Warranty
This item is backed by a Limited Lifetime Warranty. In the event this item should fail due to manufacturing defects during intended use, we will exchange the part free of charge (excludes shipping charges) for the original purchaser
Features:
- Sold as a Pair
- Molded ends exactly like the originals
- Hardened plastic mounting pins
- Reinforced screw holes like factory
- Smooth soft fine grain rubber
- Fits Hardtop, T-Top and Convertible Models
- Produced by Fairchild Industries
Lifetime Warranty
conlinj
05-15-2006 03:44 PM
