Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Plans Demsions For Tubing Bender
Old Feb 11, 2004 | 01:53 PM
tyty49's Avatar
Car: 91 Maro & 97 Ram & 05 Roadstar
Does anyone have any plans or know where to get them for a tubing bender? I need to bend 1 1/4" .083
Old Feb 11, 2004 | 07:59 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
http://www.pro-tools.com/index.htm
Old Feb 11, 2004 | 11:33 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
Harbor Freight has a 12ton bender. I don't know if its what you are looking for though. I'm going to try and get one tomorrow.
http://order.harborfreight.com/EasyA...ht/results.jsp
HDC has them:
http://www.homier.com/default.asp?pa...ies.asp?dept=1
Old Feb 12, 2004 | 05:03 AM
ede's Avatar
ede
i used a conduit bender for years to build kart chassis with. bought one from harbor freight a few years ago and have never used it.
Old Feb 12, 2004 | 08:58 AM
JERRYWHO's Avatar
I have one from http://jd2.com/ works great.
Jerry
Old Feb 13, 2004 | 09:02 AM
Project86's Avatar
See Tube Bender Thread it is about 14 pages long. Around page 12-13 you will find a link to CAD drawings with dimensions for a JD2 style bender.
Jeff
Old Feb 14, 2004 | 08:58 AM
tyty49's Avatar
Thanks a lot!
Old Feb 25, 2004 | 08:03 PM
johnsjj2's Avatar
Car: 1991 Z-28
This may help out more. I bought all the pcs. needed for the die, and the hardened steel rod. Total cost with shipping was $266. I am using 1/4" steel for the frame.
http://www.blindchickenracing.com/To...bingbender.htm
Old Feb 26, 2004 | 06:26 AM
Mathius's Avatar
Keep in mind, that a pipe bender and a tube bender are two different things. It has to do with the way wall thicknesses are measured, so if you buy a pipe bender, you may not get it to do what you want.
Mathius
Old Feb 26, 2004 | 12:34 PM
johnsjj2's Avatar
Car: 1991 Z-28
Good point. I bought a pipe bender from HDC a couple weeks ago. I soon realized it won't bend tubing w/o kinking it. After searching the net, I found the blind chicken racing site, and went to work. Parts should be here the first of March.
Old Feb 26, 2004 | 05:37 PM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
I used a Ridgid pipe bender(an American brand I believe) to make a rollbar for 2 cars amongst other things.Very easy to use.It just so happens that the tubing I used fitted right into one of the pipe bending formers.Pipe is usually measured on the INSIDE diameter whereas tubing on the OD. Heres the rollbar in my friends car,mine is the same.Hope it goes well it's certainly the way forward.
Old Feb 26, 2004 | 09:04 PM
Project86's Avatar
Here is a link to a modified Pro-Tools similar to the blind chicken bender, the guy replaced the bottle jack with a small hydraulic ram. It's at the very bottom of the page.
Pro-Tools Modified Bender
Old Feb 27, 2004 | 12:03 AM
halfpint's Avatar
A helpful hint to all,
If using a bender that "pipe crush" is a concern- simply fill the pipe first with sand. This will help prevent it from collapsing.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
z 28 jari
Sep 14, 2021 10:03 PM
Chas91Z28
Oct 22, 2015 10:12 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
75bike
Sep 20, 2015 09:37 PM
