Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
stick to tig conversion
Old Feb 11, 2004 | 11:33 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
any one have any sugestions on setups that would be good to use with a miller bobcat stick welder. i would like to be able to tig with this unit as it is all ready mobile
Old Feb 12, 2004 | 12:42 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
tig is stick weld do you mean mig
Old Feb 12, 2004 | 01:02 AM
c4boom's Avatar
Engine: l98 and lo5
tig is not stick welding tig welding you use a tungsten electrod to strike up a arc ant then you have a inert gas to sheild the pool. stick you have a electrode coated in a flux. i am looking for a reg and tig torch setup to run gtaw on a smaw
Old Feb 12, 2004 | 04:58 AM
ede's Avatar
ede
all you need is an air cooled torch, argon, and a flow meter for DCPG tig. your welder would or should have a setting for tig so the engine diesn't have to start the arc from an idle. if you have one of the older or cheaper bobcats you may not be able to do it. does your machine have a switch for tig and mig?
Old Feb 12, 2004 | 05:01 AM
ede's Avatar
ede
long time ago i worked with a guy name russel briggs, but he pronounced it wussel bwiggs, any way he needed to tack something with 7018 and all he had was a tig rig so he put a rod in the collet and welded away. it all melted together on the second rod. morel of the story is stick and tig ain't the same thing.
Old Feb 12, 2004 | 10:52 AM
c4boom's Avatar
Engine: l98 and lo5
yup sure dose i do mostly industrial welding at the moment and i am looking to get into fab work. thats why i sound so ignorant when it comes to tig never needed one befor. thank you for the reply
Old Feb 12, 2004 | 11:32 AM
c4boom's Avatar
Engine: l98 and lo5
sorry was in a rush on the last post forgot to ask who makes a good air cooled torch i hate sales men down at the shop near me they will sell you a peice of crap and tell you it is gold if they can make a extra buck off it
Old Feb 12, 2004 | 02:02 PM
ede's Avatar
ede
weldcraft get one with a hand valve on the torch. you'll be all set for everything but white metals. cost is around 200, 250 or so will get you a few extra pieces you'll need.
Old Feb 12, 2004 | 04:25 PM
c4boom's Avatar
Engine: l98 and lo5
thanks for all the help first thing i am going to do is make up a jig so i can make some runners for my tpi
Old Feb 12, 2004 | 11:50 PM
jocww's Avatar
true but having filler wire is just like having fluxcoverd wire i mean same movements and all i should shut up now
Old Feb 13, 2004 | 07:29 AM
ede's Avatar
ede
c4 is your bobcat ac/dc? you need ac for white metals, alumminum, magneisuim, etc. you'll also need a high freq unit to weld them with. don't know that i ever saw high freq on a bobcat. for what you're wanting to do i'd get a foot pedal too. you should have a remote connecter on the bobcat for a foot pedal, or feeder box. guess it'd be no differant than on a eletric powered machine. give your supplier a call and ask them.
Old Feb 13, 2004 | 01:14 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
nope if you want to tig with a bobcat you need the hi freq box....i dont think any of them came with one
Old Feb 13, 2004 | 02:02 PM
ede's Avatar
ede
383 you don't need high freq for tig, with a boobcat or not. you do need high freq for white metals.
Old Feb 13, 2004 | 02:14 PM
Car: '91 Camaro RS
thats what i meant......cause you were talkin about white metals before
Old Feb 13, 2004 | 03:18 PM
ede's Avatar
ede
sorry guess i got confused
Old Feb 14, 2004 | 12:44 AM
c4boom's Avatar
Engine: l98 and lo5
thanks guys i am going to head down to the local shop with my new found knowledge and try not to get ripped off tomorrow
btw yes it dose have a ac weld option.
Linson
Oct 24, 2025 02:00 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
