Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Fender Bender
Old Feb 14, 2004 | 04:17 PM
Bitchin89RS's Avatar
Car: '89 RS
Engine: LT4
Fender Bender
Does anyone know what the best way is to go about beating out a rear quarter pannel? I got backed into in a parking lot and I don't have the money to take it to a collision repair shop.... Any info would be greatly appriciated
Old Feb 14, 2004 | 04:21 PM
jon_volk's Avatar
how bad is it crumpled? If there are some real good creases in it the metal would require more work than its worth to keep that panel. If its real bad i would find a good 1/4 off another car, cut the old one off and weld the new on.
Old Feb 14, 2004 | 04:24 PM
Car: '89 RS
Engine: LT4
It's not to bad noticable but not crushed... to put it this way the plunger is just a bit to small to pull the dent out... it's about 7 inches all the way across and only one crease....
Old Feb 17, 2004 | 01:49 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Is it anywhere you can remove plastic to get at the back side of the fender, got backed into in the pits one day, luckily before the new paint, but was able to remove plastic and pop it out from the inside. I've also heard dry ice will sometimes pop out some minor dents with no major creases to hinder the "pop back" when the metal shrinks.
Old Feb 20, 2004 | 01:04 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
I heard of guys that have a big rubber end on a air hammer and "work" from the inside...
Old Feb 20, 2004 | 01:29 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
getting to it from the backside with a rubber hammer and/or body spoons is your best bet, with a small pick hammer on the outside.
The dry ice is more for hail dents, door dings w/o creases. Say, no more then half/sliver doller size.
morrow
Jan 13, 2024 12:29 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
jovibuilt
Oct 18, 2015 08:12 PM
kkirch15
Interior Parts Wanted
Oct 15, 2015 02:21 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
