Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Oil pan fabrication...?
Old Feb 10, 2004 | 12:31 AM
noc_81's Avatar
First of all, I couldn't figure the best place to put this post, so please move it if I chose wrong...
I don't know if I am skilled enough to fabricate the "kicked-out" sump, but I'm sure I can piece together a decent windage screen, trapdoor, and baffle set for my stock pan.
Couldn't I just make a windage tray with some steel screening and some long hinges(?) folded over and bolted together? Also, in the case of trap-doors, what is the best design?
I might be in a little over my head, so just tell me if I am...
Old Feb 10, 2004 | 04:57 AM
ede's Avatar
ede
i modified a stock pan once, it was a lot of work, way more in time and effort than i thought it was worth after i was done. all i did was cut the sump off and weld on new metal, didn't look as good as i wanted it to either.
Old Feb 10, 2004 | 08:31 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
its one of thoes things that seems pretty easy, but ends up being a lil harder then you would think it should be...
Old Feb 10, 2004 | 09:37 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Especially when you can get them off eBay or race dedicated auctions like http://www.racersauction.com for cheap.
Old Feb 15, 2004 | 07:23 PM
noc_81's Avatar
But what about a cheap screen windage tray, or maybe some other backyard engineering? I don't have welding equip, so whatever I can bolt together from a hardware store is my limit...
Old Feb 17, 2004 | 01:46 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Sounds like one of my spend $20 to save $.02 Where your putting this thing is definately not a place for "whatever I can bolt together from the hardware store" Just what a rotating assembly likes is a backed off nut/bolt/duct tape/bailing wire slinging around in the mix Depending on yr of your block you can get a wide sump oil pan with trap door from summit for $79 and windage trays are usually $20 so for less than $100 and zero thinking, I think this may be a perfect case in point to just purchase instead of making something. Been in that boat one too many times, as I'm sure alot of guys here will relate too:lala:
Old Feb 17, 2004 | 02:33 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
you can make a crankshaft scraper by hand pretty easily.
thats suppost to be worth a couple hp.... lol.
Old Feb 20, 2004 | 12:20 PM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
I've built a few pans. it helps to have an old block to bolt it to so it doesn't warp up when you weld it. I've put trap doors, sumps, and all kinds of baffles in. Without a good welder it's not worth the trouble.
Old Feb 20, 2004 | 01:02 PM
wesilva's Avatar
Transmission: 200R4
Here's a stupid one for you. If the pan is bolted to the block, how do you weld....through the bores in the block?
Old Feb 20, 2004 | 01:05 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
from the OUTSIDE of the pan... you weld the seams on the outside.
Old Feb 20, 2004 | 02:19 PM
wesilva's Avatar
Transmission: 200R4
I thought he was including trap doors and baffles with that technique.
Old Feb 20, 2004 | 02:52 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
thoes arnt close enough to the pan rails to worry about warpage.
Old Feb 20, 2004 | 03:10 PM
wesilva's Avatar
Transmission: 200R4
I warned ya that it was "stupid".
Old Feb 20, 2004 | 03:25 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
This is an idea I would like to look into. I havent found one for my v6 engine other then the fiero, which isnt the same.
Does anyone have pictures of the inside of a windage/trap door pan?
BDR
Nov 7, 2015 03:05 PM
project89
Sep 22, 2015 09:35 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
