Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Torque Arm
Old Feb 23, 2004 | 10:09 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
Torque Arm
Anyone tried to fab one of these up, seems like it would be that hard to me, just getting some threaded ends to make it adjustable. Shoot me some ideas.
Old Feb 24, 2004 | 07:36 AM
MCas7's Avatar
I think it would be a good project to tackle. BMR and Spohn have done it and you can get some pretty hi res pictures of them if you needed some detail of how they do it. I'm sure you could build one for less than you can buy it from them.
Old Feb 24, 2004 | 03:10 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
I'm curious why it needs to be adjustable? The only aspect of the stock arm that is adjustable is that it slides in the rubber mount at the trans. I plan on making my own designed on the factory one, but I will make it out of square tubing. Probaly 1"x1" of some fairly thick tubing. Nothing fancy, just more sturdy than the stamped sheet metal piece. Well I guess I'll paint it so I guess it will be kind of fancy.
Old Feb 24, 2004 | 04:26 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
The adjustability is the part factory does'nt have and if you race your car pinion angle helps plant tires. For the most part, a basic and easy to me method of this would just be make a mount off the cross member and have the anchor point so it gives the -2 to -4 whatever you choose pinion angle. Adjustibility is nice, but once I have mine set at -3 I never plan on doing it again, hence the cross member mounting point to acheive this. Lots cheaper than buying heims. Just be sure your mounting point up front gives free movement forward and backwards otherwise you'll bind up the suspension.
Old Feb 27, 2004 | 10:34 AM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
the trick here is to use tubing with an 11/16 inner diameter. I use 1 inch DOM tubing with a .156 wall. With an 11/16 inner diameter you can run a 3/4 x 16 tap into the tubing. I have both right and left handed taps for this. It's easy to make up adjusters and whatever else you need.
Old Mar 3, 2004 | 05:16 PM
Lonestar's Avatar
Car: 1985 Firebird
Engine: 327
Transmission: TH350
The most important item to fabbing these arms is to strengthen the mounting point at the transmission. A buddy of mine kept snapping the tailshaft off his trans until we fabbed a shackle that ties the trans down to the trans crossmember better than stock. When I get to putting my Ford 9" in I am going to fab the whole assembly from scratch with better mounts.
Old Mar 10, 2004 | 11:49 AM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
i think im going to attempt making one from boxed steel. i have yet to see one being sold that is constructed of boxed material. my arms and subs are boxed, why not the TQ arm right?
Old Mar 12, 2004 | 02:54 PM
TexasLT1's Avatar
Car: '92 RS
How so? I just checked out the Spohn adjustable torque arm and it has what looks like a spherical rod bearing for the front mount. Just trying to understand why it needs to slide.
Old Mar 12, 2004 | 04:22 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
The crossmember that spohn supplies with his torque arm has the slider implemented as a kind of "pivot arm" I guess you could say. The arm attached to the crossmember through a poly bushing, and the torque arm's rod-end is attached to the arm, allowing the torque arm to move forwards and backwards. Here's a great pi from spohn's site:
http://www.spohn.net/productimages/ACF3DBB.JPG
Old Mar 12, 2004 | 07:12 PM
TexasLT1's Avatar
Car: '92 RS
Ahhhhh, that makes sense then, couldnt see that detail in the photo I looked at.
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
