Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Cheap ram air ideas
Old Mar 14, 2004 | 01:09 AM
SilverZ28's Avatar
Car: 83 Z28 silver
Engine: 350 Reman
Transmission: bw T5 5-speed
Cheap ram air ideas
I have a 83 Z28 and want to get a better air induction system, I don't really care if it gives me a lot more power but any home fab systems got to be better than the stock air cleaner right? I have seen a headlight ram air system on a eclipse and thought it might work on my Z28. Any ideas would help thanks
by the way it is stock except for a reman 350 in place of the LG4 5.0L thanks
Old Mar 14, 2004 | 04:08 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
take out the high beams. or u can use pcv and have the air enter on the sides of the front license plate
Old Mar 14, 2004 | 02:18 PM
SilverZ28's Avatar
Car: 83 Z28 silver
Engine: 350 Reman
thanks for the input. also have you ever seen it done or done it your self? I just bought this car about 2 months a go and the carb is radicaly detuned for gas mileage and to pass colorado emissions but have no plans to change that right now, just looking for cheap ways to improve performance and not hurt the mileage much
Old Mar 14, 2004 | 08:05 PM
jocww's Avatar
i helped a friend do it to his 67 chevelle. think about it this way do u use ur hi beams alot. he didnt so we did it that way instead of a dif hood. for my elco i put a aero scoop on it. the only bad thing if u put it on the out sides of the license plate it restricts flow to the rad. u dont want it to go down to far cuz then water gets in. the stock z dual snorkel works just fine for stock cars hope this helps
Old Mar 14, 2004 | 09:50 PM
SilverZ28's Avatar
Car: 83 Z28 silver
Engine: 350 Reman
thanks Jocww i will see what will work best, by the was what is the stock z dual snorkel it must not be on my car mine is a single tube leading to the left near the head light, also if i found one do you think it would help? Thanks for all your help Jocww
Old Mar 15, 2004 | 12:34 AM
jocww's Avatar
mine is from a l69 option i have two tubes one to the left the other to the right. and its right above the head lights. i dont know how the air gets in but it does. i know that the air cleaner is almost 200 for new and 150 for used so hope u have some deep pockets. jsut dont get an open cleaner cuz the bay is hot with all the shi t we have in there
Old Mar 16, 2004 | 12:29 AM
SilverZ28's Avatar
Car: 83 Z28 silver
Engine: 350 Reman
I have still am not sure what i am going to do but i will post before and after pics if i do some of the other ram air ideas. thanks for all the input Jocww
Old Mar 16, 2004 | 02:19 PM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
I got some ram-air ideas on page 2 of my website.
I have TPI but i am sure you can use the same concept for your ride.
Old Mar 16, 2004 | 06:53 PM
jocww's Avatar
u know what would be sweet but ud have to fabricate it all. would be get z3 fenders or lowflyins fenders and put the air ducts that way. u can see pics of his fenders on my post on shaving.
no prob thats wat these forums are here for. to help people
Old Mar 16, 2004 | 09:37 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
wow! the (l69) duel one is 150.00 used? I know of one just on the top of my head
evilstuie
Apr 14, 2016 08:52 PM
86IROC112
Sep 7, 2015 01:37 PM
mustangman65_79
Aug 11, 2015 03:17 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
bryan623
Aug 10, 2015 11:33 AM
