Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
welded axle tubes
Old Apr 21, 2004 | 08:13 PM
bubba377's Avatar
welded axle tubes
is anybody welding the axle tube on the 7.5 10 bolt .I have heard that this should be done so the tubes don't spin in the housing
Old Apr 21, 2004 | 08:55 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
ive also heard it should be done, but i also heard it HAS to be tig, but i dont know anybody who tigs, and all the shops around me are rip offs
Old Apr 21, 2004 | 10:03 PM
bohn333's Avatar
Car: 1987 Trans am
I welded my axle tubes, i used a mig welder. It was a 3 phase 480V one though. The tube itself would twist in half before the weld broke. TIG welding in best for aluminum, stainless and making real pretty welds because its clean. MIG can be just as strong and just as pretty if done properly.
Old Apr 21, 2004 | 10:16 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
what are the tubes and center section? where in wisconsin are you? wanna do it for me, ill throw a few bucks your way
Old Apr 22, 2004 | 04:09 AM
bubba377's Avatar
I have a mig ,tig ,and stick welder so that is not a problem thank's for your info .Did u fasten the rear someway to keep it from moving while it is being welded.did u weld them solid or stitch weld them.thank yo foryour time
Old Apr 22, 2004 | 04:31 AM
ede's Avatar
ede
https://www.thirdgen.org/techbb2/sho...hreadid=235171
Old Apr 23, 2004 | 08:02 PM
bohn333's Avatar
Car: 1987 Trans am
I'm in Oshkosh, i'll do it if you bring me the rearend, but your probaly better off just taking the rear out and taking it down to a weld shop in your area. They shouldn't charge you much to just weld the tubes real fast.
6speedIROC
16
Mar 15, 2023 08:33 PM
gixxer92
May 18, 2017 11:20 AM
NZKnight
Oct 15, 2015 02:47 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
