Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Fiberglass headliner??
Old May 15, 2004 | 11:09 PM
Tricked-Out-Toy's Avatar
Car: 91 Z28
Engine: Lt1
Axle/Gears: 3.70 auburn pro 9"
hey guys i was wondering has anyone tried to do a fiderglass headliner for the hard tops,NOT T-topd?? if soo how did it work out and how did u do it? i was going to try it and using the original head liner for the template make the mold and go from there. this would only be my second fiberglass venture! if anyone has any pointers i sure could use them. thanks in advance - TOT
Old May 16, 2004 | 09:41 AM
Mathius's Avatar
Are you worried about destroying your old headliner? If not, you could always just glass over it. If you want to make a mold though, I would cover the old one with something like aluminum foil, or something that can be smoothed and molded relatively easy, then coat it with wax and fiberglass around it to make a mold.
Mathius
Old May 16, 2004 | 04:45 PM
Car: 91 Z28
Engine: Lt1
well i never thought about just goin over my old one? would i need to just strip all the liner of and leave the foam? and would i need to do it any differently than if i started from scratch? thanks for the help guys- TOT
Old May 17, 2004 | 05:14 AM
Mathius's Avatar
Just strip off the old material and sand down the foam/cardboard part until there's no more headliner fabric or loose pieces stuck to it.
Mathius
Old May 17, 2004 | 07:09 AM
Car: 91 Z28
Engine: Lt1
great! thanks guys! ill post pics as soon as i get it done
Old Jun 4, 2004 | 12:19 AM
Burn EM!'s Avatar
Cool Idea. I want pics!
Old Jun 17, 2004 | 04:32 PM
Car: 91 Z28
Engine: Lt1
well guys i did it and rather tahn sand the hell out of it and what not i test fit it and it fit great!! and i know it would have looked cool but the next day i put my cage in and now i cant get it to clear between the roof and the main hoop its to stiff so now its back to the drawing board. ill prolly still do it in fider but ill have to do some smoothing out where the seat belts went through. i think im going to try glassin a dash cover see how that turns out, anyone do that? and have pics?
Old Jun 19, 2004 | 12:21 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I think I've seen a fiberglass dashpad done before. It was on someone elses car. The backseat housed several subwoofers on a fiberglass wall and the dashpad was painted a neon green to match the car and subwoofer box. It might have just been spray paint on the vinyl dashpad though.
If you get into fiberglass and like working with it, then you might try taking the dashpad one step further and fiberglass a complete dash assembly. I doubt it would be that hard to get some foam to cut out your design on and make a mold. Harwood use to make a fiberglass camaro replacement dash but the model has been discontinued for a long time. I've seen them on ebay rarely ususally worth around 400 to 500 bucks.
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
