Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
DIY front air dam with pics
Old Jun 10, 2004 | 08:42 AM
pecha's Avatar
Car: 98 T/A
Engine: ls1
This will work for ppl who don't have an easy access to stock parts or can't just go to the junkyard and pick whatever they need.
I built my air dam using a flower pot, a knife, a screw driver, a marker and screws. I used a flower pot cause it's cheap, flexible, you can get it anywhere (not all of them are made in america ) and soft enough to work with (cut, drill holes)
I cut one of the longer walls off using a knife.
so I got sth like this
then I cut the remainings of side walls and the bottom
the next step is to mark the places where you have to drill holes so they match with the existing holes under your radiator
when I had the exact locations of the holes I drilled them using the same knife I used for cutting, then I screwed the air dam into the car and that's it
Old Jun 10, 2004 | 09:32 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
IMO that may be too flexible and fold over when you are going at any sort of fast clip. Only way to know for sure is test it. I probably would do it only in a bind, I just couldn't trust the durability of that plastic, nor the flexability resistance in the wind.
If it's that hard to find parts, or the proper plastic, you may want to try to just buy some plexiglass or lexan and heat and bend it to conform? It's as easy to find, manageable and stiffer. You could even get creative with some of the plastic sheeting that many companies are starting to sell.
Old Jun 10, 2004 | 10:24 AM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Pecha -- great idea for those of us living in places where Third Gen parts may be hard to obtain. If the plastic proves too flexible at high speeds, the addition of an aluminum frame extending part way down the sides might be useful.
Old Jun 10, 2004 | 10:26 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
yup the only way to tell would be to test it......if youre not overheating then youre good. besides, with it being as flexible as it is going over anything and scraping wouldnt damage this as much
good job!
Old Jun 10, 2004 | 10:54 AM
josh1988's Avatar
Car: 1993 Trans Am
Engine: 5.7 LT1
that's pretty resourceful, always cool to see good ideas like that, I did get a brand new one off of ebay for 20.00 though, and im pretty sure the seller had internaional shipping, so if that doesn't work out...
Old Jun 10, 2004 | 10:57 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Originally posted by Duck
... the addition of an aluminum frame extending part way down the sides might be useful.
That would probably be good. If he got thin enough stock it would allow him to bend it back to conformity if it ever got hit.
Old Jun 13, 2004 | 02:37 AM
SC82TA's Avatar
Car: 1982 Pontiac Trans Am
Engine: Stock carbed 305
Transmission: Stock 200C
Yeah that looks good..I may have to do that...I've been running without one for a while...although I don't have overheating issues. Plexiglass is too brittle and would just break. Lexan might work, but its probably more expensive than the pots. As for the plastic being to flexible it might be a good thing.
Old Jun 13, 2004 | 10:19 PM
onebinky's Avatar
We've made them for a couple F-Bodies out of aluminum angle for the top mounting rail, and then ridgid semitruck mud flap cut to fit for the bottom portion.
Worked out great, and one has been in use for 4+ years now.
EDIT: Is your car right hand drive? Any pics if it is???
Old Jun 28, 2004 | 11:42 AM
TROOPER's Avatar
Car: 89 formula
Engine: yup its in there
Transmission: no ,i had my shots
i used 4 inch lawn edging you know that black plastic for around flower beds ill try and get a photo of mine
Old Jun 28, 2004 | 11:58 AM
pecha's Avatar
Car: 98 T/A
Engine: ls1
no, my car is left hand drive
Old Jun 29, 2004 | 01:50 AM
NEEDforSPEED's Avatar
Well, looks kinda thick... but i cant be there to see it...
all i can say, is...... fab some brakets!!!
if it was me id use aluminum ...
Old Jun 30, 2004 | 09:38 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Like the above, I'm curious as to how it holds up at higher speeds.
When i read "flower pot," i thought "How's he making one with preformed clay?"
Old Jun 30, 2004 | 10:45 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
ROLFLMAO :lala: its been a while since this thread has started hopefully he has had time to get it up to high speeds....any updates on how it holds up pecha?
Old Jun 30, 2004 | 12:55 PM
pecha's Avatar
Car: 98 T/A
Engine: ls1
when I was doing over 120mph for few minutes the temperature started going up it's good till 100mph continuosly (did it few times)
I tried to avoid brackets or supports cause the dam would break if I hit sth but I guess they are inevitable
what do you guys think about holding it at the right angle with a string or a line (d/k how to explain it) sth that could be attached to the dam and in front of it holding it at the right angle, this way if I hit anything the dam doesn't break but the string does
I d/k I'm confused, I guess for now I'll be avoiding high speeds
Old Jun 30, 2004 | 02:34 PM
MikeC.86Roc's Avatar
Why not just look on Ebay or ask Hawks for instance how much the original one would cost to be shipped to you. Can't see you spending much more then $50? If you are going that fast that often then you certainly NEED it...
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Catcher55
Aug 15, 2015 07:08 PM
