Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Built an electric water pump...
Old Jul 8, 2004 | 10:30 PM
black85camaro's Avatar
Car: 85 Camaro
Engine: 350 Carbed
Transmission: Stock 700r4
I just got done fabing one up. I used a heater motor and some custon pullies that I got from a buddy. They came off of a convaier (sp?) at his work. The pullies are ribbed so of course I used a small ribbed belt. I mounted the motor in where the alt. was. It is currently 1/2 rigged up because I am racing at the fun friday night tomorrow but I will make some brackets for it and mount it better later on.
I have some pics of the install but I don't know how to shrink the pics.... Can someone tell me how and I will post them.
Also I am not sure if the motor will burn up since it will be put through alot.
-Terry-
Old Jul 9, 2004 | 02:21 PM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
Whats the amp rating on the motor?
Old Jul 9, 2004 | 02:53 PM
rolling-robert's Avatar
Car: z-28 x2
Engine: 355ci and 305ci
Transmission: th350 and th350
thats a cool idea... hmmm... makes me think of making 1 too...
Old Jul 9, 2004 | 11:14 PM
Car: 85 Camaro
Engine: 350 Carbed
I dont know the amp rating. The motor gets hot when its running but holds up to the task. I did go through 2 switches though. I guess I need bigger switches. I have pics of the install but dont know how to shrink them. If someone could tell me I would post them. There are about 4 pics.
-Terry-
Old Jul 10, 2004 | 02:00 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
I'd suggest using relays instead of putting all that power through a switch.
To reduce your pictures, there should be an option to 'resize' or 'resample' the images when veiwed in your photo program.
Old Jul 10, 2004 | 04:48 PM
ljnowell's Avatar
Sounds like an awful risky system to trust to a homemade pump. If it went out you could have serious problems, even with a temp gage ( you dont always look at it). I think that it would be best to put some sort of kill switch on it, so that if it failed it would shut down the engine, that or install an LED in the dash, so you would know if it failed. Just my .02
Old Jul 10, 2004 | 06:27 PM
Car: 85 Camaro
Engine: 350 Carbed
I am going to install a led light so I know if something went wrong... I only use the car on the strip. It is trailed to and from so reliability isnt really an issue with me. I mean I only drive it a 1/4 mile at a time
I dont have an option to resize in my viewer... I guess I could send them to someone to host them or resize them for me. Any one care to help me out???
-Terry-
Old Jul 10, 2004 | 10:26 PM
ljnowell's Avatar
Thats cool, we were on the same track with the LED. Makes good sense to me if its a strip only car. How much does this cost in relation to a new electric pump?
Old Jul 11, 2004 | 01:10 AM
Car: 85 Camaro
Engine: 350 Carbed
It cost me nothing. I got the pullies from a buddy at his work and the belt also. The motor is just a heater motor so I used the one out of the car. The only thing I paid for is the wire and switch.
Old Jul 11, 2004 | 01:35 PM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
download irfranview, it's really easy to use and it does a great job with pictures
Hotrodboba400
Dec 10, 2019 07:07 PM
tommy z-28
Oct 6, 2015 10:58 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
buckshot63
Sep 10, 2015 09:15 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
