self built engine
Car: z-28 x2
Engine: 355ci and 305ci
Transmission: th350 and th350
self built engine
built my first 355ci engine
old vetteheads 1.94/1.50 (ported myself)
cranecam 272
alu roller rockers
forged flattop (9.72) pistons
hv oil pump
holley 600
mallory hei
edel. perf. inlet
stubstack
dynomax shorty headers
dual exhaust with cheapo mufflers
dual electric fans
all metal oldsmobile radiator
2.94 rearaxle (soon to be 4.10 dana60
2500 hughes stall converter (th350)
b&m improver kit stage2
first testdrive: broke tires loose from start, but above 3000rpm it was kinda lousy.
next day i checked the advance, was only 22 degrees advance at 2500rpm!
so i calibrated it to 35 degrees, then i noticed the throttle cable was miss-adjust, i could only give 50% throttle max!
so ill fix that tomorrow , so now im excited what will happen if i give full throttle with 4.10 gear ratio!
i mean, it broke the tires loose with 2.94 gears and half throttle!
cranecam 272
alu roller rockers
hv oil pump
holley 600
mallory hei
edel. perf. inlet
stubstack
dual electric fans
)2500 hughes stall converter (th350)
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by onebinky
Cool, does it actually work as advertised? 30cfm on a 650 carb is pretty good increase.
if you have a large amount of room above the carb, yes, it can help the air flow smoothly into it.
if you dont have a couple inches above the stack, it can hurt flow.
Terrell351
Jun 13, 2021 01:13 PM
