Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Trailer hitch
Old Jul 15, 2004 | 06:07 PM
Soulrev's Avatar
Car: Formerly - 87 T/A, 87 Bird.
Trailer hitch
I'm going off to college in October and I don't think my T/A is gunna hold all of my belongings.. Just wondering if any of you have heard of someone installing a trailer hitch on a 3rd gen..
I was thinking something removable because this will be the only time I'll ever need it, and we're talking a very very small trailer, like a u-haul type thing, big enough to carry a military crate..
Suggestions or ideas?
Old Jul 15, 2004 | 08:16 PM
Don 91RS's Avatar
I've seen a guy pulling his yard equipment on trailer behind a 3rd gen. I bought a hitch for my Tahoe a few years ago from etrailer.com. Check them and ebay.
Old Jul 15, 2004 | 09:37 PM
TBS84Camaro's Avatar
Car: 1984 Camaro Berlinetta
Engine: SB 350
Transmission: TH350
I think JcWitney has one
Old Jul 16, 2004 | 10:09 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Curt Manufacturing part number 11117 fits a 91 Formula just fine. Bolts on. Try www.curtmfg.com, or your local trailer hitch supplier (I used Joe's Trailer Hitches and Truck Supplies in Plano, TX). I just got a Class I (up to 2500 pounds capacity) since I just have a little pickup box trailer I have to use once or twice a year. This is a 1.25" receiver hitch so the ball is not sticking out from under the bumber all the time. Works great!
Have a Great Day!!!
- Vern
Old Jul 18, 2004 | 05:40 PM
onebinky's Avatar
I think hidden hitch makes one as well.
Old Jul 19, 2004 | 10:16 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
My parents are weird. When they owned my old 87 formy they put a class III on the back and towed their old 21' boat. Baaaaad; but it did it. Looked like a barbie set showing up at the launch, bright red firebird and bright red trimmed boat.
Old Jul 21, 2004 | 12:00 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
my car had a hitch on it when i bought it.... think it was hidden hitch, its outside. looked factory but i dont know about towin any real weight on a unibody, funny thing is... my car was originally v6....... 6 bolts held it on, one i had to cut off using dremel(not easy). the thing had like a 1200lb gross cap.
Old Jul 22, 2004 | 03:01 AM
83 Crossfire TA's Avatar
I know a couple of autox’ers that tow a small trailer with a couple of sets of tires, shop jack, tools… with one. There’s a few choices out there, the issue becomes what exhaust does it clear.
Old Jul 22, 2004 | 04:51 AM
nick418's Avatar
Engine: L98, Hemi 6.2
no wonder why we have our reputation Jk guys , Ive seen a 3rd gen pull a lil trailer once up in NH
Old Jul 22, 2004 | 08:58 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
true true. my hitch was already in the car when the dude i bought my car from did his "custom" exhaust. getting the hitch out required some major pulling sideways of the 3" pipes which just happened to be right under the hitch bracketry...
Old Jul 28, 2004 | 02:48 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
I have one and I do not need it. you can have it just pay for shippin.
Old Aug 3, 2004 | 05:49 PM
camarochevman's Avatar
i just took mine off i think they look dumb as hell
Old Aug 7, 2004 | 02:07 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I betcha Reese makes one too. Likely at least a Class 1, if not Class I and II.
The Reese hitches are pretty good stuff, and are pretty cheap. Where I work, most Class I hitches go for around $140 (cdn) and Class II around $160 (cdn).
I've never actually had to look one up for an F-body though, so I dunno for sure if they do make one for it.
Old Aug 7, 2004 | 10:27 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
My '84 has a hitch ('til I figure out how to remove it!) This is a pic just after I bought it.
Old Sep 3, 2004 | 09:45 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I have seen alot with them, I saw a hidden one on a 87 formula, I think the only way I would put one on my car would be to tow my buddies 5.0
Old Sep 4, 2004 | 08:54 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
And cue the banjo music Billy-Bob.
Old Sep 7, 2004 | 02:56 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
The best way I have seen is a custom built hidden hitch. I've seen it on a 3rd gen in the local SCCA group (for driving to the track without a chase vehicle). He took a second gen rear licence plate holder (they flip down to get gas in them) and cut a hole behind the plate area in the 3rd gen bumber cover, then just folds the plate down and puts an extender into the receiver behind it when he needs to tow his trailer. One straight bracket across from one side to the other is all he did and it cleared everything just fine. The wiring plug fits flush behind the 2nd gen plate holder too...
Parts can be found at Northern Tool, or just about anywhere that carries trailer parts.
Old Sep 25, 2004 | 06:35 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
ive seen many a thirdgens on trailer and in front of trailers but never one pulling a trailer......LMAO....
Old Sep 26, 2004 | 10:59 AM
3rdgenloser's Avatar
Car: 1984 Trans Am
Engine: 305 V-8
Transmission: t-5
lol
yeah my Trans Am has a tow hitch. I'm not sure how much it can pull but its definatly there. I bought it like that, but watch out i've knocked my shins plenty of times getting into the hatch lol.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
mattcanty
Oct 12, 2015 11:08 AM
92projectcamaro
Sep 29, 2015 07:07 PM
drumstixer
Sep 29, 2015 03:02 PM
manifoldsrme
Sep 17, 2015 11:40 PM
