Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Electric water pump installation....
Old Aug 10, 2004 | 08:18 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
im not sure if i posted this stuff before, i havent been around this board much lately....
heres my electric waterpump setup.....i used this pump cause i already had it and its been working mint since march now....
in order to make clearance for the alt belt to run under to the crank pulley i made these extensions for the water pump flanges....
Old Aug 10, 2004 | 08:21 PM
Car: '91 Camaro RS
it took a little work to get them perfect so they would seal, and i used about 2000000000 gaskets in the process but it came out good....this also made more clearance and allowed a much shorter lower hose.
then i had to fabricate an idler pulley to run the belt down underneath the pump to the crank pulley...
i used an off the shelf idler pulley with a bearing and bushing, and welded a nut into a piece of tubing, braced it up, shimmed it so the belt lined up and here it is
belts never come off, up to 7000rpm
Old Aug 13, 2004 | 12:33 AM
onebinky's Avatar
Pretty cool Is that just regular square tube stock you used for the waterpump extensions?
Old Aug 13, 2004 | 05:51 AM
ede's Avatar
ede
i have the same pump. never thought of doing that, instead i spen an obsene amount of money on a moroso bracket kit for the alternator and pulley for the crank to drive it. wish i'd went the same route you did.
Old Aug 13, 2004 | 02:04 PM
Car: '91 Camaro RS
yup its 1/8 wall 1" sqaure tubing
the flanges are cut from 3/16
Old Aug 13, 2004 | 02:05 PM
Car: '91 Camaro RS
ya it took a little time to get everything just right, but its mint now......i wasnt even aware there was a bracket setup lol
Old Aug 13, 2004 | 02:21 PM
ede's Avatar
ede
something like 300 dollars from moroso, bracket kit and a crank pully kit
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
