Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Your battery in your trunk
Old Nov 21, 2004 | 02:05 AM
Mathius's Avatar
Relocating the battery to the trunk for weight transfer is relatively easy to do, but I'm interested in hearing exactly where you guys put yours, how you mounted it, and lastly how you vented it and where to?
I really don't like the look of those plastic battery boxes, nor do I want to pay the price for a stainless one from summit or whatever. I want to be able to put my battery in the trunk and somehow seal it off from the rest of the car. I'm looking for ideas. Actually they don't even have to be third gen if they can be adapted to a third gen it would be ok.
Mathius
Old Nov 21, 2004 | 02:27 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i bought the BMR relocation kit and moved my battery back in the spare tire compartment. i also have a Optima battery which is sealed and has no battery acid (for like a gel instead of water). so thers no problems about venting. ill try and snag a picture for you tomarrow if its not raining.
im goin to be takin it out soon since i had some rust damage back there and how it mounts it split the seam on the i think wheel well/ 1/4 panel area. looks like an easy fix but looks are decieving.
Old Nov 21, 2004 | 04:05 PM
masseyiroc's Avatar
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
i work at the drag track here..ihra rules say you need a approved box vented to the outside and also a switch to shut it off.if you plan to do any racing
Old Nov 21, 2004 | 04:12 PM
masseyiroc's Avatar
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
you could also build some sort of firewall you dont need the box and vent then.heres our rule if it can help you.. -All batteries must be securely mounted and may not be relocated into the drivers or passenger compartment. The use of rubber tie downs or j-hooks are prohibited. All relocated batteries must have a master shut off switch located outside of vehicle and clearly marked on/off. Trunk mounted batteries must be separated from drivers compartment by a firewall or be contained in a Steel or an IHRA approved poly box and be securely mounted with minimum 3/8 diameter fasteners.
Old Nov 21, 2004 | 08:24 PM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
some sites seel a kit but its not sealed.and the only reason mines isnt in the trunk is because the rules in the track with the cut off switch
Old Nov 21, 2004 | 08:36 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
thats what the NHRA/IHRA tell you must do. ive been to the track running my car twice since i relocated my battery and never got checked. some people just dont do there jobs.
Old Nov 22, 2004 | 03:36 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
yeah i been time were they dont check me either
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
drumstixer
Sep 29, 2015 03:02 PM
