Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Fuel Cell
Old Dec 16, 2004 | 10:46 AM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
Transmission: Powerglide
Axle/Gears: Moser 31 spline / 4.86
Fuel Cell
Has anyone here put a fuel cell in a Camaro. Have any pictures or info on where to mount it? I'd like to put a fuel cell in my camaro so can have an accurate amount of fuel in the car each time I race..
Old Dec 17, 2004 | 09:31 AM
KAOSRacing's Avatar
How big of a cell (capacity wise) do you want? A small cell (3 to 5 gallons) should fit in the bottom of the hatch area with very little work. A larger cell (10 to 15 gallons) will require removal of the gas tank and cutting out a large portion of the hatch area.
Then you have to fit a "firewall" to seperate the fuel cell from the driver's comparment.
Old Dec 17, 2004 | 11:05 AM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
thats what I was worried about was making something to separate it from the drivers compartment. I was going to go with a 4 or 5 gallon cell. The 4 gallon vertical cell would fit perfect in the back. But im not sure on the NHRA/IHRA rules for fuel cells in a full bodied car. I still have all factory interior in my car and want to keep it that way.
Old Dec 17, 2004 | 12:03 PM
vetteman9368's Avatar
Car: 91 Z28 NHRA stocker
Transmission: Jerico 4spd
you can fit an 8 gallon cell where the stock tank was, you will have to fab up some brackets, you then use and aircraft acces hatch to get to the cap. Perfectly NHRA legal.
Old Dec 17, 2004 | 02:18 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
a bigger one wont fit there?
Old Dec 17, 2004 | 05:02 PM
I'm saying thats what i KNOW will fit
Old Dec 17, 2004 | 08:20 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Is the car a strip only car? or do you do the street strip thing?
Crazy as it sounds it's be alot easier and cheaper to just install a small 2 or 3 gallon cell under the hood with it's own separate fuel system. That way whatever's in the main tank will be the same all day and you can just top off between rounds.
I personally keep a full tank as long as possible really helps keep my 60's consistent-might be a tad slower than if running on fumes but this is bracket racing!!, depending on how many rounds I'll watch the gas gauge and if it moves a wee bit I'll throw more gas back in to try and keep the weight the same. But with both vehicles I run I've found you can be 5-6 gallons low and it makes no differecne in ET/mph what so ever.
Old Dec 17, 2004 | 10:48 PM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
well right now its just a strip car, but its still street legal if i renew my tags and insurance. I just never know how much fuel is in the car cause my gas gauge sucks and always has. I bracket race it sometimes, but mostly run a 7.0 heads up class. .400 pro tree. So i was just looking for a little more consistantcy with a smaller fuel tank/cell so i can have the same amount in the car every pass.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
colton_carlson
Mar 8, 2019 12:21 PM
89fast5oh
Sep 27, 2015 09:04 PM
92camaroJoe
Aug 13, 2015 06:07 AM
