Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Project Fuel Cell In Motion!!!
Old Feb 27, 2005 | 09:11 AM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
ok over the next Few Weeks, Depending on weather I am In the process of Fabing a Fuel Cell into My car.
The Fuel Cell I am using is a Jaz 12gal w/sender and 2" sump.
THIS IS THE IHRA & NHRA REGULATIONS ON THIS
Code:
When permitted by class regulations, fuel tanks located outside
body and/or frame must be enclosed in a steel tube frame constructed
of minimum 1 1/4-inch O.D. x .065 chrome moly or .118 mild-steel tubing.
All fuel tanks must be isolated from the driver's compartment by a firewall,
 Steel must be .025 Aluminum .032
completely sealed to prevent any fuel from entering the driver's
compartment. All fuel tanks must have a pressure cap and be vented
outside of car body. A positive-locking screw on fuel-tank cap is
mandatory on all cars. Insulated fuel tanks prohibited. When used, fuel
cells must have a metal box protecting the part of the fuel cell that is
outside of body lines or trunk floor, excluding hose-connection area in
rear. Non-metallic  fuel cells or tanks must be grounded to frame.
I am in the process of Fabricating the Sheet Metal Box, I already Created Templates for the box out of Poster Board, Just need to Trace them on to .025 Sheet Metal and A few Cuts and Bends Later I will be ready to Start Welding the Box. I will Keep You updated with Pics Comming soon
Old Feb 27, 2005 | 11:38 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Ok The Sheet metal Is Cut Out, I will Get Pics soon but I am adding a Pic of the cad Drawing, and a the actuall Cad File for I can Email it to you
Attached Thumbnails Project Fuel Cell In Motion!!!-c-documents-settings-oem
Old Mar 15, 2005 | 05:26 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
I posted updates here
https://www.thirdgen.org/techbb2/sho...71#post2232771
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
g.l.mos
Aug 22, 2015 12:02 AM
