Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
how fabercating a supercharger for a 3.4
Old Mar 9, 2005 | 06:53 PM
Coult_91's Avatar
Car: 91firebird, 2000 camaro
Engine: 305 tbi,K&N, edelbrock intake & 3.8
Do you think you could get a 3800 supercharger to fit a 3.4l or should i keep waitin for a kit?
Old Mar 9, 2005 | 08:09 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
a 3.8 s/c on a 3.4 could be tough. well, that depends on if you mean a roots type blower. if that's what you mean, there are other ones available that would probably be easier to work with. if you mean a centrifigul s/c, then about any of them could be adapted.
Old Mar 9, 2005 | 08:44 PM
colonboy14's Avatar
Car: Trans Am
Just weld on another 2 cylinders and 2.3 liters. Should do the trick.
Old Mar 10, 2005 | 11:55 AM
Coult_91's Avatar
Well does anybody anyone that has made a supercharger work or their something close with little modding to get one on the car? any ideas would help?
Old Mar 11, 2005 | 01:09 PM
Coult_91's Avatar
Me and a friend were looking were we could put a bracket because we know someone could make one for us, but what else would i have to worry about?
Old Mar 14, 2005 | 07:39 PM
PhantomFE3's Avatar
Car: 1984 Z28
Transmission: TCI Streetfighter TH350
Axle/Gears: 4th gen 3.42
the 3.4 is a 60* motor and the 3.8SC (L67) is a 90* motor, the intake manifolds are different, although with some modification and some custom manifold adapters it could be done with the stock L67 manifold
otherwise youd have to make a special lower intake manifold
Old Mar 19, 2005 | 06:49 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
www.rsmracing.com/firebird.htm
already a kit for 3.4l 4th gens, it probably will take very little work to get that working in a 3rd gen, if any.
main problem i can see would be any differences in the plenum/tb on the 3.4 if you kept your 2.8 stuff and put it on the 3.4. but i dont have any experience whatsoever with 4th gens, so dont take my word for it.
Old Mar 19, 2005 | 10:23 PM
83 Crossfire TA's Avatar
Anything can be done if you want to badly enough. You’d have to either fab up a manifold or some brackets and plumbing. Here are some pics of the M90 setup on my brother’s f@#d (while the car was being redone in a body shop):
toronto formula
Nov 10, 2015 06:17 AM
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
92projectcamaro
Sep 29, 2015 07:07 PM
-=Z28=-
Sep 24, 2015 10:21 AM
