Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
5mm x .5 die or super fine thread fasteners.
Old Mar 18, 2005 | 10:00 AM
charliemccraney's Avatar
Car: 1988 Firebird Formula
Engine: 305 (LO3)
Transmission: 5 spd manual
Does anyone know where I can find a 5mm x .5 die or of a supplier of super fine thread fasteners?
Thanks.
Old Mar 18, 2005 | 02:52 PM
Dynodan's Avatar
Car: 1992 firebird
Engine: 305tbi
Try the companys fastenal, or Mcmaster Carr for these items.
Dynodan
Old Mar 18, 2005 | 03:14 PM
Engine: 305 (LO3)
No luck at either of those places. However, I did find one at J&L Industrial Supply. It's an adjustable die for about $10.00.
Old Mar 18, 2005 | 06:33 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
Axle/Gears: ford 9in 4:56 to 1
try
US bolt and screw
Old Mar 24, 2005 | 06:41 PM
Brazen's Avatar
Car: 91 Z28, t-top, 5.7l ZZ4 rebuild
Engine: 5.7L TPI
Transmission: 700r
Re: 5mm x .5 die or super fine thread fasteners.
Thanks.
Believe it not not... your local Ace hardware should have these! I had to find some really strange taps and no ****.. they had a HUGE selection. On a side note, they also carry very small Torx and security bits... like those needed to remove the "butterflies" in a TPI throttle body.
Jim
Old Mar 25, 2005 | 07:33 AM
Engine: 305 (LO3)
I tried Ace Hardware and Howard Brothers Hardware, the two best hardware stores in my area, and they didn't have any that fine.
I ended up finding several dies after searching and searching. MSC, J&L, and Rutland tool have them. I got a M5x100 part thread allen bolt, cut off the threads and re-threaded it with the 5x.5 die. Worked like a charm.
I just have to make some fuel lines, do a little welding, paint and this project will be finished!
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Andrew6.688
Dec 13, 2015 10:59 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Wade787b
Sep 29, 2015 01:15 PM
