Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Welding Question
Old Mar 24, 2005 | 06:37 AM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Welding Question
Ok I am Installing a fuel Cell in my car so I baught a Lincoln sp-135 Mig. Well the welding I am doing is on .031 Sheet metal and .118 Square tubing, On the .031 Sheet metal I am using .025 Mig Wire and 75/25 Gas, Now what would you recommend for welding the .118 Square tubing, .030 Flux Core or .030 Mig wire and Gas, I know I would get less contamination with mig and gas but some say if it is thicker than 16guage to use flux core. I just need some Usefull knowledge.
Old Mar 24, 2005 | 07:21 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
With that size welder it should be rated to 3/16" thick steel using .030 wire and CO mix and not have any trouble producing good welds. One trick i found years ago with mine, when welding thicker material with the same small welder I would switch to .035 and it would penetrate much better on 1/4" thick stuff. You could also opt to buy 100% argon as it will penetrate deeper into the weld as opposed to the CO mix.
Flux will burn hotter at the expense of apperance with slag and spatter.
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
MintWS6FORMULA
Oct 19, 2015 08:53 PM
redmaroz
Aug 16, 2015 11:40 PM
