Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
AC Delete Cover Plate
Old Mar 27, 2005 | 04:41 PM
[VU]Juan's Avatar
Car: 84 TransAM
Engine: Chevy 355
Transmission: TH350
So I got rid of my AC while I was doing the 355 swap, since then I was running around with huge holes left on the firewall from where the AC used to sit. I finally got around to making a plate to cover it, here's the end result.
I'm just glad I won't die from all the dust, heat, and smoke being generated by the engine. I actually enjoy driving it now
What do you guys think? Did it all with a 6" grinder and a piece of sand paper lol... what did all you guys do about this AC delete issue?
Old Mar 28, 2005 | 12:08 PM
[VU]Juan's Avatar
Car: 84 TransAM
Engine: Chevy 355
Transmission: TH350
16 views and no replies, I guess it didn't impress anyone lol...
Old Mar 28, 2005 | 01:59 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Well..................it's kinda big. I mean it looks good but you used WAY to much sheet metal to fill up 2 small holes. Oh well.
Old Mar 28, 2005 | 03:23 PM
[VU]Juan's Avatar
Car: 84 TransAM
Engine: Chevy 355
Transmission: TH350
actually... there was more holes than just the 2 on there... when installing the new 355 engine we had to cut a hole (dumb *** mistake) in order to get some "things" done... so the firewall looked like a mess, it IS big but I'm guessing it will look a lot smaller once it's the same color, it will blend in then...
Old Mar 28, 2005 | 03:28 PM
Guido's Avatar
Car: 2000 Trans Am
I did something similar using a piece of aluminum.
Old Mar 28, 2005 | 04:44 PM
[VU]Juan's Avatar
Car: 84 TransAM
Engine: Chevy 355
Transmission: TH350
yep, that's what I had in mind, will look a lot more at home after I paint it black...
Old Mar 28, 2005 | 05:05 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
That's not AC delete, that's EVERYTHING delete
Old Mar 28, 2005 | 06:31 PM
[VU]Juan's Avatar
Car: 84 TransAM
Engine: Chevy 355
Transmission: TH350
well... yeah... lol... good weight reduction though
Old Mar 28, 2005 | 08:10 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
AC? These things came with AC?
Old Mar 29, 2005 | 10:45 AM
[VU]Juan's Avatar
Car: 84 TransAM
Engine: Chevy 355
Transmission: TH350
yeah, some even paid extra for such features lol
Old Apr 11, 2005 | 09:27 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
i made a panel back in the day that fits exactly where my a/c box came out. traced it on some aluminum, cut it out and drilled some holes, mounted it back with the same bolts i took the a/c box off with.
Old Apr 23, 2005 | 10:56 PM
SloWhite_Z's Avatar
Car: 82 Z28 Camaro
Engine: 350 cid.
Transmission: Turbo 350
old and new the sheet metal is like 20 gauge so it weighs like less than a pound and I took out my dash and all of the heater stuff behind it
Old Aug 3, 2006 | 07:19 PM
knightrider2278's Avatar
Car: I have a 1987 firebird
Engine: it has a 7.5l 455 in it
Transmission: i have a turbo 400
Axle/Gears: im not sure their factory
that looks good if you dont want any heat when its cold you need your blower motor for heat
Old Aug 3, 2006 | 08:10 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
im thinking about removing it on the trans am since its not gonna be a winter car and its not gonna have a/c ever refurbished
but if i were to do it i would want it done right
pieces of steel to fit in the holes flush and welded in smooth with a mig welder
hmmm
good luck
Old Aug 7, 2006 | 09:12 PM
AJ89Irocz's Avatar
Car: 1989 Camaro Iroc-Z
Axle/Gears: 2.77 Posi
That looks awsome man.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Kenwood
Sep 4, 2015 05:50 PM
mantaguy
Sep 2, 2015 10:42 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
