Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
how to make a 91 wiper motor work in my 82
Old May 6, 2005 | 08:54 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
has anyone ever made this work, I've run out of ideas and I am ready to just graft a small section of firewall into my 82's firewall so it looks like it belongs there.
I've tried shims and nothing looks good. Lets not turn this into a leave the car stock battle, I'm putting 91 harnesses in my 82 and I cannot get the 82's wiper motor to run off the 91 harness so it's time to figure out how to make the 91 wiper motor fit my car
Old May 8, 2005 | 01:15 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Ahhh...you've already noticed that it doesn't bolt up, and won't fit into the same recess intended for the original large motor.
In addition to swapping in the later harness, you also need to change the wiper switch in the steering column with one for an 84-up as the wiring changed then.
The 82-83 had +12V fed into the motor and grounded through the switch for the various functions. 84-up had the +12v going to the switch, then to the motor, which was itself grounded.
Old May 8, 2005 | 05:31 AM
Jproz1167's Avatar
Petes
You got it. thats my issue ... electrically it has all 91 stuff in it just have to mount the wiper motor lol
Old Jul 5, 2005 | 10:01 PM
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
add in another victim, i was just about to paint my engine bay when i realized the newer motor wouldnt fit. im just going to the junk yard and cut out that section of firewall and weld it into my car. PIA but gotta do it to make everything work.
Old Jul 8, 2005 | 12:49 PM
Jproz1167's Avatar
hey IROC post some pictures of how your doing it, I cut a section from my 84's firewall and I'm attempting the same thing, seems pretty thin to weld.
Old Jul 8, 2005 | 06:08 PM
IROC_5796's Avatar
http://d3v.yafro.com
heres some pics, its just sheet metal mig should work fine. i left the 2 bolt holes from the old one, new motor boilts into those 2 holes.
Old Jul 16, 2005 | 10:36 PM
Jproz1167's Avatar
nice work IROC, gave me some ideas on how to tackle this problem. I'm going to be pulling my motor for a 350 swap so will weld a 84 up piece in to and repaint my engine compartment.
Old Jul 17, 2005 | 05:10 PM
IROC_5796's Avatar
good luck with your enigine bay.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
TheExaminer
Aug 26, 2015 04:59 PM
slade5612
Aug 11, 2015 07:19 PM
