Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
How to achieve the interior plastic pattern?...
Old Jul 22, 2005 | 11:23 AM
JerseyMark's Avatar
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
Hey everyone,
I am about to undertake making some door speaker pods. I dont want to carpet them. I want to make them match the dark grey plastics that are in my car. How can I get that same pattern into a different material? Is there a fabric that will match it closely?
Thanks,
Mark B
Old Jul 24, 2005 | 12:57 PM
dahaus's Avatar
Car: 1985 IROC
I'm hoping you get a response to your question. I have been wondering about that for years. There has to be a way.
I have been thinking about buying the book about molding plastic. I think they offer it in the Eastwood catalog.
Old Jul 25, 2005 | 01:42 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
there was a few threads about this in the body and interior section...
I posted in one about fixing cracks in a dash, then trying to match the texture... (same sorta idea).... One suggestion was rubberized undercoating, since it gives a bumpy appearance... Haven't tried it yet though...
Old Jul 25, 2005 | 01:53 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
look here: http://www.charlestonracing.com/XMB/...id=301#pid5109
near the bottom of the page (after you go thru all the BS) theres a pic of a guy i know that had custom gaugepods made..
it used this spray stuff (links and pics in thread)
Old Jul 25, 2005 | 04:17 PM
JerseyMark's Avatar
Engine: 96 LT1
AWESOME!! Now I have to get to work!
If anyone else goes to that thread... Go to page 2 for the pics & top of page 3 for the link.
Old Jul 26, 2005 | 05:09 PM
dahaus's Avatar
Car: 1985 IROC
This is great. I have been wanting to build a fiberglass dash for my camaro, but I wanted to get the original texture to give it a factory look.
This also means a person could to wheels tubs and build new interior pieces over the tubs. Still having that factory look.
Old Jul 27, 2005 | 08:29 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
now that i have a couple more seconds, just incase that thread disappears:
He used SEM Texture Paint.
to put the texture on these fiberglass gauge pods:
Attached Thumbnails How to achieve the interior plastic pattern?...-dash2.jpg
Old Jul 27, 2005 | 09:26 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
wow...that stuff is awesome! i might have to order some of it...
Old Aug 18, 2005 | 02:59 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
if you are after flat plastic they sell that with the pattern.i will be using that stuff to make my new guae cluster (in a million years when i can drop $600 on guages)
Old Aug 28, 2005 | 12:46 AM
Kuejo's Avatar
Car: 1988 IROC
Plastic texture
There's a product out there called Plastex - a plastic repair resin product (VERY easy to use). Initially marketed to the crotch rocket croud for repairing their (frequently) broken plastix effects. Also works good for boat and aircraft reapirs. Expensive, but does a good job. In their higher end kits they include a piece of "molding putty". This stuff is like a medium hard rubber until you heat it to 120 degrees, and then it gets soft and pliable, and is fine enough to take the fingerprints off your fingers and transfer them to the plastic resin stuff!! This putty was included specifically for the purpose of recreating original textures in small repairs.
It would be a lot more work to get that entire surface textured, and the previously mentioned ideas might work better - but check this stuff out at least. I've seen it at the local Harbor Freight (in Camarillo, CA) and I have a vey good friend who is a distributor - if you can't find it any other way I'll be happy to put you in touch with him.
Jonathan
Old Aug 30, 2005 | 12:19 AM
Kandied91z's Avatar
i was all excited until i saw it was sem texture coating. i would like to see how that was done with the guage pod. i have the sem texture paint in black and it looks absolutely nothing like the above. granted it's black and does have SOME texture, but nothing like the above...?
Old Aug 30, 2005 | 10:00 AM
86IROCZ's Avatar
I use sure-tex , but it's gray so you have to paint it. Unless your interior is gray
Old Sep 5, 2005 | 05:49 PM
Kuejo's Avatar
Car: 1988 IROC
The Plastex will definitely give you the original texture, but it would be VERY time and effort consuming to do it, simply because it would be a large piece to fabricate. The putty is really designed to repair small areas, not to fabricate entire pieces.
Old Sep 5, 2005 | 06:45 PM
gnatshop's Avatar
Car: '94 GMC Sonoma
Engine: 406 sd TPI
Textured paint
I haven't tried this yet for interior parts, but a little while back at Home Depot, I picked up some Rustoleum spray can textured finish paint for a home project.
It gave a very nice textured finish. I liked it so well that I picked up some in black to use on the valve covers of my Grand National.
It only comes in a limited choice of colors. To paint your choice over it, you would have to use a number of really light coats to avoid filling the texture too much. Thickness of top coats could be used to get the texture you want.
David
Lake Worth, FL
gnatshop@bellsouth.net
Old Oct 1, 2005 | 01:35 AM
fitbmxseries1's Avatar
Car: 1988 trans am GTA
Engine: 350 tpi
i worked at a detail shop for a while and we used to have to repair some cracked dash pads all we really would was sew it back togeather then put a flexible glue over it but to get the same pattern thats on the rest of the dash we would make almost a rubber stamp by spraying some vinyl shine on a clean part of the dash then putting the rubber glue on a small peice of wood and pressing it wher ethe vinyl shine is (stops it from sticking) then we would pull it up and we would have a stamp of the pattern, then we would just stamp it on the part with the vinyl repair glue (semi hardend) ..... ive only dont it twice first time was a total mess and the second time came out perfect. this way is only good for small areas though
Old Oct 20, 2005 | 12:41 AM
Kaukasion's Avatar
Car: 84 z28
Engine: older 350, details unknown
Transmission: th350
Axle/Gears: factory limited slip
ive used wrinkle paint dried with a heat gun
then painted over that
it worked pretty good but the grain is a little larger looking than stock
its worth buying a bottle and testing it on something to see what you think
1992 Trans Am
May 10, 2023 07:19 PM
C409
Jan 21, 2016 08:29 PM
69 Six Pack
Oct 5, 2015 07:51 PM
MORREALE5
Sep 13, 2015 09:16 PM
