Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
87 heads
Old Aug 29, 2005 | 12:11 PM
mopain's Avatar
Car: 1986 trans am
Engine: 305 tpi
Transmission: th700r4
87 heads
i have a set of '87 305 tpi heads. i would like to put them on my 86 tpi motor. is there any type of machine work that needs to be done to them before i make the swap.
any help welcome.
Old Aug 30, 2005 | 10:26 PM
onebinky's Avatar
You will need to elongate the center bolt holes on the intake and make some wedge shaped spacers to go under the bolt heads. If you search for it you'll find all the details you need.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
