Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Heavily Modified LT1 Intake???
Old Oct 8, 2005 | 04:20 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
I have tried many different searches with no luck. Not to long back someone posted a heavily modified LT1 intake to look similar to the TPIS intake. If someone has pics, or can put me in the right direction it would be greatly appreciated.
Old Oct 8, 2005 | 07:34 PM
LT1guy's Avatar
Car: 1987 Trans Am
I think this is what you are looking for (LT1 intake as a TPI replacement):
http://www.lt1intake.com/
Old Oct 8, 2005 | 08:36 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Thanks for the response, but that wasn't what I was looking for. This person literally took a grinder and opened up underneath the main part of the plenum on a LT1 intake, so it is similar to the TPIS system or to airgap style setup.
Old Oct 8, 2005 | 09:29 PM
LT1guy's Avatar
Car: 1987 Trans Am
Coo, I wasn't aware anyone had done that...I'd like to see it too!
Old Oct 8, 2005 | 09:39 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Yeah, I seen a post about it around a month or 2 ago. I am doing the LIT intake mod and would love to see his work again for some ideas.
Old Oct 10, 2005 | 02:31 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
No one has seen this LT1 Intake all fabricated up?? Hmmm
Old Oct 13, 2005 | 10:29 AM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Hmm never seen it, id like to however.
Old Oct 13, 2005 | 10:39 AM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
The guy did an amazing job too. I would love to do the same thing, but need to chat with him if he would give me some pointers...
Old Oct 13, 2005 | 05:40 PM
83 Crossfire TA's Avatar
Here, I make no guarantees how long I’ll leave these up, I don’t remember where it was that I got them, and if you’re the owner and don’t want them up just tell me and I’ll take them down:
Old Oct 13, 2005 | 06:58 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Mark!! Your the MAN!!! Thanks a million!! It would be nice to figure out the man with the skills who made this bada$$ piece! Hopefully he will not mind, and maybe even say a few words. My hat goes off the the man with the tools, and of course you too Mark.
Thanks again!!!
Old Oct 13, 2005 | 10:26 PM
Really, if you look at an LT1 manifold and what he ended up with, it’s not all that amazing a job. As a matter of fact, someone totally **** retentive, after seeing what he’s done could probably make a better looking setup, but I have to admit, that it took some real guts for the guy to first pick up the plasma cutter and grinder and start hacking at the manifold. If it wasn’t for the fact that I’ve seen it done I’d worry about running in to an EGR or IAC passage in the space below the plenum and winding up with something that cannot be fixed.
Looking at it does give me a couple of ideas also.
First, cutting it up like that does give you the perfect opportunity to cut a little more and fix some of the LT1 manifold’s problems from undernieth, where the work won’t be obvious/ugly. You can increase plenum volume from the bottom, basically not changing the overall look of the setup and even maybe reprofiling the runners into a better shape which people have done before by adding aluminum to the top of the runner behind the injectors.
Also, this kind of dissection lends a lot of possibilities for the LT1 -> SBC swappers out there, since now you have a not more room to run cooling lines.
Old Oct 17, 2005 | 05:53 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Well I got my complete LT1 Intake this past Saturday, went and pulled it myself at a local wreckers from a 94 Caprice. Engine ran fine when it came to the lot. Took my all of 45 minutes to pull it, and cost me only $75 Canadian. The condition is very decent consider our winters, so it's off to the cutting boards! LOL!!
Old Feb 26, 2006 | 10:44 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
The new Edelbrock catalog for 2006 that we just got in at my store, shows a new manifold available for LT1 engines... LT1 Air-Gap. Check it out in the catalog (not up on their site yet though, strange)..
Old Feb 27, 2006 | 02:04 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Edelbrock is toting that they'll be releasing those soon due to the fact that the LT4 products were just discontinued from GM. In reality Edelbrock's manifold has been in the summit catalog for over 7 years. Date keeps getting pushed back.
there's a whole thread on this intake over at ls1tech.com in the lt1 section
Old Feb 27, 2006 | 08:12 AM
thirdgen88's Avatar
Car: 1995 Corvette
Is the one you're referring to a port-injection manifold?? I know the carb manifold has been out there.. Look on Pg 14 of this PDF of the 2006 catalog (Pg 59 on the paper one):
http://www.edelbrock.com/automotive_...manifolds).pdf
Old Feb 27, 2006 | 11:11 PM
Firebat's Avatar
Thats the one many are waiting for...
Old Feb 28, 2006 | 10:53 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
the idea I had on the one I just sold was I to weld a plate across the bottom at the front only (inside lifter valley). add alittle meat near the coolant ports on top , grind them through so they worked like a normal sbc coolant passage and grab a old quad water neck (or make a similar looking one just smaller on the lath) long story short put a 3.8 v6 thermostat in the front of the intake just above the eng. block. if you cleaned up the welds it would look real clean and factory looking
I guess looking at the above picture you could just build a box off the front like a miniram
Old Mar 2, 2006 | 07:52 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
I know the guy that made the red LT1 intake pictured above. I don't want to give out his info without his knowledge, but PM me if you're interested in talking to him about it. It's very impressive...
Old Mar 3, 2006 | 02:43 AM
What I'd like to know is if that's powedercoated or painted and what he used?
Old Mar 3, 2006 | 05:43 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Modifying like that looks like it might mess up the IAC ports internally. I guess it doesn't matter if you use an aftermarket throttle body because they mess up the IAC ports as is usually (bad idle).
Looks neat though.
Old Mar 10, 2006 | 01:22 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
I'm almost certain that it's paint, not powder coat
Old Mar 10, 2006 | 05:45 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
If I had to guess its painted just because in the 1st pic you can see a line of paint of the side of the diamon plate.
Then again he could have taped off the diamond plate and powdercoated it also..
hard call without seeing it in person.
heres red mini ram I did.
http://www.cecoatings.com/images/coa...iram/Engine%20(4).jpg
Old Mar 10, 2006 | 05:46 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
[QUOTE]Originally posted by TPl383
[B]If I had to guess its painted just because in the 1st pic you can see a line of paint of the side of the diamon plate.
Old Mar 10, 2006 | 07:11 PM
After looking at it, I’m pretty sure that that is paint, mainly because you can see some epoxy that is covered in some spots and not in others… I know that there is metal bearing epoxy that you can powdercoat over, but what are the chances…
How did you do the stripes, did you wipe them off before baking, mask them somehow or sand them after baking?
Old Mar 10, 2006 | 09:50 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Sanded 1st then they get masked off. . Then polished after the parts coated. Sanding it off after would be a PITA.
Ive never tried the epoxy they clame can be coated over. I've talked to a few people who have and they said it doesnt work that great. The powder cures diff and you can tell right where the epoxy is.
Old Mar 10, 2006 | 11:04 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
That is what you did on mine......
Old Mar 10, 2006 | 11:07 PM
Yea, I've heard similar.
Look at the back shot of the manifold where he has the egr stuff filled and the front shot where you can see the epoxy holding the diamond plate on. I'm pretty sure that's paint...
Old Mar 25, 2006 | 07:59 AM
ZROLimitRacing's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 5.0 305 Code H
I like the idea of the LT1 intake but i really dont like the diamond plate on it.
Old Dec 29, 2007 | 03:16 PM
06andersen's Avatar
Re: Heavily Modified LT1 Intake???
with that mini ram intake is it the same or better than the stealth or w/e its call its not called a mini ram intake?
Old Aug 4, 2009 | 02:15 PM
snake70's Avatar
Car: 1979ta, 1981 formula
Engine: 400 sbc 403 olds
Transmission: th350 th400
Axle/Gears: 308 373
so does any one have a step by step process of converting the lt1 intake
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
92projectcamaro
Jan 18, 2016 08:00 AM
theurge
Aug 21, 2015 12:46 PM
