Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Japanese and their fab skills.. 3rd gen roll cage
Old Oct 14, 2005 | 08:46 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
you gotta hand it to them.. they do make some cool thing.. check out this crazy cage they made 3rd gen roll cage
Old Oct 14, 2005 | 11:27 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
that looks awesome but i would guess that most of it is just extra weight. big on the looks, though.
Old Oct 14, 2005 | 11:50 PM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
That does look really trick.
Bet that TTop car wont squeek anymore.
Old Oct 15, 2005 | 12:34 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Looks pretty. Too made it's not legal below 12 seconds.
Old Oct 15, 2005 | 08:08 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
You are right, however, I don't think they do alot of drag racing over there
Old Oct 15, 2005 | 08:11 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Too made? How did I type that?? It should be "Too bad"
Old Oct 16, 2005 | 02:21 AM
911rsq's Avatar
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
Old Oct 16, 2005 | 02:29 AM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Furthermore, how did I not notice?
Old Oct 16, 2005 | 03:33 AM
avitet's Avatar
translation the best i could
UP of body rigidity of ƒJƒ}ƒ? of T ƒo?[ƒ‹?[ƒtƒ‚ƒfƒ‹, furthermore it aimed for corner ring characteristic ”‚ Ì UP and became production that this time this roll gauge is managed. Until you call, also the safety when crashing it has not considered. The material which it does not consider the race/lace participation which this time parallels to race/lace regulation with one off production, uses related to detail and rigidity UP and luxurious SUS304 ¥ 42 made ƒ³, when paint and being the rust unnecessary was involved even in beauty when completing. At the same time as for the body joint the rust of the weld there is no worry as all SUS volt/bolt finishing blows, and furthermore made removal and re-installation yes ”‚ È ones. the number of points made 25point, but while drawing up the plan, it calculates and to attach, to nighttime the day when it continues there was a job. It dispersed the burden which falls on the body with roll gauge unifying the rear coil over upper adapter unit, to each frame, it made to improve rigidity. The around of the cockpit while checking, whether guaranty of the passenger space and inconvenience and the like when getting on and off it is not, became being settled. Interior in genuine interior cleanly return. Vis-a-vis completion weight 45kg genuine ƒ}
Old Oct 16, 2005 | 11:03 AM
305q_ta86's Avatar
Transmission: 5 spd
Re: translation the best i could
lmfao
Ok, my reply is:
Huh? You mean you did not account for safety, only for cornering rigidity? Would it not be beneficial to also make sure it will not get people killed in a crash? Sort of a false sense of security thing?
Translation:ハァッか。中間角を付ける剛性率の安全を、しか説明しなかったか。またそれが人々を衝突で殺されて得ないことを確かめることも有利でないか。種類の事偽の安心感か。
Old Oct 17, 2005 | 02:10 AM
avitet's Avatar
no i mean thats what it said as far as i can tell on their site
Old Oct 17, 2005 | 08:25 AM
Tricked-Out-Toy's Avatar
Car: 91 Z28
Engine: Lt1
Axle/Gears: 3.70 auburn pro 9"
Ok I read the translation twice and not sure If i understand it. they made the cage out of thinwalled tubing? and its ment just to strenthen the chassis? if thats the case then you could easily use thicker walled tuning for the main hoop and a couple other points similar to a 4 or 6 point cage. I think that set up looks awesome and I bet its stregthens the chassis a TON! and it only weights a 100lbs! thats amazing.
Old Oct 17, 2005 | 11:06 AM
avitet's Avatar
thats what i thought and ya i guess you could use a thicker wall tybing to help strengthen it as a form of protection
Old Oct 17, 2005 | 12:20 PM
avitet's Avatar
thats what i thought and ya i guess you could use a thicker wall tubing to help strengthen it as a form of protection
Old Oct 17, 2005 | 11:49 PM
911rsq's Avatar
Transmission: yes
Old Oct 18, 2005 | 12:40 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
A little off topic. The rear air spliter on that camaro is trick. Can anybody translate cost in greenbacks? I would also assume that you would have to do away with the stock muffler location?
Old Oct 18, 2005 | 04:48 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
YEN to $ is about .0087 yen to the dollar.. i got that from Google search yesterday..
the rear wing is about 548$.. the hood says is $1458
Old Oct 19, 2005 | 12:54 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Not the wing. The Air splitter underneath the rear of the car. Where the stock muffler goes. How much?
Bottom left picture.
http://www.grace-co.co.jp/3d_rcing_w...cing_wing.html
Old Oct 19, 2005 | 02:05 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
well just take their Yen price... and multiply it by .0087 to give you the price..
*edit*
just noticed that they are not selling that part.. its just the wing they have pictured..
looks like a one off fabrication deal... should be "too hard" to make...
Old Oct 19, 2005 | 02:30 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Hmmmmm. I knew I should have taken Japanese in high school.
Old Oct 23, 2005 | 10:32 AM
Vader's Avatar
Like the cage, the "aerodynamic" features are likely just for looks. Typical.
Old Nov 6, 2005 | 08:47 PM
srdynamics1's Avatar
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
Because it is a Japanese tuner company's purpose built show car it has to appeal to their market.
Rigidity is the stated purpose of that cage. Japanese tuner cars are typically set up for time attack and drifting events, which are pretty much solo. Nascar style cages aren't required.
Old Nov 8, 2005 | 01:39 AM
Aweasel's Avatar
Car: Red '89 IROC-Z
Engine: 350, Patriot 195s,
Transmission: T56, Hurst Shifter, Alum. DS, 3.73
The thing under the bumper is called an air diffuser, it helps aerodynamics and creates a more even stream for the air to flow under the car...they'd be stupid for the street because they are generally made of carbon fiber and who the hell wants to spend 1000+ for something that doesn't do anything but "look cool" on a street car. Seriously, it's for sportscar racing, they probably don't even need it...hell, if they were really into racing would they use 2 coffee can fart pipes for the exhuast on that car? If they were smart they'd run some good flowing headers and some straight pipes or something...possibly a cutout. Car looks cool but then again, it sorta looks stupid. Dig the cage though, nice work, a little much but still the craftsmanship is excellent.
Old Nov 26, 2005 | 02:38 AM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
I'm diggin on there brembo kit on page 3 pretty neat
Old Nov 30, 2005 | 03:52 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
According to the pics on the site, the car is into drag and road racing.
http://www.grace-co.co.jp/drag_top1/...race_top1.html
After making the "heat extractor" hood, I doubt they would build anything just for looks
Old Nov 30, 2005 | 04:06 PM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
good to see people like domestic cars in japan , I heard they go for like 7 or more grand over there even in just ok shape
Old Nov 30, 2005 | 08:30 PM
1983Fbody's Avatar
Car: transam, el camino
Engine: 415
Fortune cookie, domestics in japan would be like honda or kawasaki. It looks like a decent design, why the tranny tunnel needs all that reinforcement I don't know, unless they were running some kind of shorter torque arm. The fit and finish is awesome.
Old Dec 4, 2005 | 04:11 PM
Car: 89 Formula
Found they have a vid of the car running
http://www.grace-co.co.jp/img/interclub/interclub.wmv
Seemed kinda rickity to me but thats probably because of the carbon hood flapping in the breese
Old Dec 7, 2005 | 11:32 PM
Engine: 350 tpi
You know i bet that they have a similar message board for 3rd gens in japan... They may not be quite as popular there, but lately ive seen more and more 'domestics' modified in japan. I think it would be pretty interesting if we could swap ideas with those guys somehow...
Old Dec 9, 2005 | 11:43 AM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
May I ask why that cage isnt aloud below 12 seconds without being flamed?
Old Dec 9, 2005 | 12:18 PM
Car: 91 Z28
Engine: Lt1
The tubing is to thin, its not to NHRA specs
Old Dec 9, 2005 | 02:08 PM
crrllmich's Avatar
Engine: L03, LS1
O Ok so if you did the same cage with thicker tubing it would be fine.
Old Dec 9, 2005 | 02:17 PM
Car: 91 Z28
Engine: Lt1
Ya but with the added weight it wouldnt be worth it, the pipes they used were similar in thinkness to exhaust tubing which is fairly light. I bet my 6 point cage weighs more that whole cage. although a "Hybrid" cage similar to theres where you would substitute thicker tubing in areas like the main hoop, side bars and rear bars, and then fill in the rest with the thinner tubing. I would think this would get you past the inspection and have a SUPER stiff car.
Vintageracer
Jan 10, 2020 05:33 PM
Warlocksirix
Sep 3, 2015 12:26 PM
neekolzun
Aug 24, 2015 04:59 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
