Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Cold air intake!!
Old Feb 25, 2006 | 01:12 PM
INTIMIDATOR Z's Avatar
Car: 1987 IROC
Engine: Turbo 293ci 4.8l
Cold air intake!!
dont know if this goes in this category but ill try..
well i had my exhaust guy see what he can build me in the forms of a cold air intake for my IROC and this is what he cam up with.
tell me what you guys think.
Old Feb 25, 2006 | 01:21 PM
85_ZED28's Avatar
Car: '85 Z28
interesting, i'd yank those foglights
Old Feb 25, 2006 | 01:23 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
Does that clear the hood?
Old Feb 25, 2006 | 01:24 PM
Car: 1987 IROC
um he had to chop my hood. right now it looks all nasty but im gonna clean it up a little later.
Old Feb 25, 2006 | 02:39 PM
JBert's Avatar
Car: Looking
That looks like 3'' piping to me?
I wonder if 2.5'' would make a big enough difference in terms of hood clearance?
Old Feb 25, 2006 | 03:44 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
It looks like well........ an exhaust. very interesting though.
Old Feb 25, 2006 | 03:55 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
looks like a chic straddling your core support with air filters for slippers
Old Feb 25, 2006 | 04:10 PM
Car: 1987 IROC
heres what the hood looks like at the moment but im gonna clean it up and put some sheet metal..
Old Feb 25, 2006 | 04:28 PM
Lo-tec's Avatar
Honest opinion.
You could have accomplished the same airflow with a single 3" setup using supercharger (or exhaust) mandrel bends and black rubber marine exhaust pipe, ran it into the inner fender, and hidden a single K&N cone filter. Clean and factory looking without hacking up the hood.
I looked for a smilie for thumbs down, but couldn't find one.
Old Feb 25, 2006 | 04:32 PM
BT283's Avatar
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
i maybe the only one but i think it looks bad a$$, love man. But if you want to get it to not look like exhaust pipe you could always paint it black! but i like it!!
Old Feb 25, 2006 | 04:38 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
looks interesting.
I had this SLP unit on my old 86 Trans Am and it looked factory,
Old Feb 25, 2006 | 04:46 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
I'm not really feelin it. There were definitely better options out there. But if you chromed it, I may change my mind.
Old Feb 25, 2006 | 05:04 PM
Car: 1987 IROC
i just wanted osmething different then what everyone has or can buy.didnt really care about cutting the hood. all that matters is i like it.
Old Feb 25, 2006 | 05:24 PM
Abubaca's Avatar
eh, it's cool I think. The only problem is GM's stock piece is pretty darn good looking to begin with. It flows well enough for most engines, and it's already cold air. No need to change it in my opinion....
....but I still think your set-up is cool.
....you could get some mini-panties for shows like this guy's blown LS1 at G9 last year!
Old Feb 25, 2006 | 06:26 PM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
thats badass
Old Feb 25, 2006 | 07:07 PM
Bluejae's Avatar
Car: 1988 Formula 350
Engine: L98 350 TPI
Transmission: 700-R4
I think it's great that somebody out there is trying to find out a different way from the "norm" to create a CAI. I like the way it looks as is color wise of course just clean up the hood some or maybe running a cowl induction hood would give you clearance or some kind of hood that had a power buldge in the center. I really like the brushed look, but I think eventually I would do something to prevent the hot under hood air from heating up your intake which could be rememdied by the cowl induction hood or maybe a powder coating could be done. I think I would try to test the airflow with and without the foglamps in place and if minimal change between the two keep the foglamps in place to "hide" the filters somewhat with an addition of some stainless steel expanded metal to protect the filter from debris.
Old Feb 25, 2006 | 07:28 PM
KonArtist's Avatar
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
Every guys dream
Nice set-up I just can't stand the way our cars looks when you remove the stock air ducts..............opens up the area around the hood latch too much for my taste
Old Feb 25, 2006 | 08:01 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
great idea and props to you, but the exhaust piping throws me off a little bit.
I'd remove those fog lights if you decide to take it to the track or something.
Old Feb 25, 2006 | 09:24 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
that looks all bloated... perhaps chroming it would help a bit.
props for a DIY job.
Image removed- Please don't waste server space with pictures that have nothing to do with the thread. Thanks.
Old Feb 25, 2006 | 09:54 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
i think it looks pretty cool. but i would definitely remove the fog lights. you'd be suprised at how much air those foglights block. i would do that if i didnt like my fogs so much and if it would clear the hood. ive been wanting to make one that goes from the throtle body to where the battery is but i dont want to move my battery. anyone else made some custom cold air kits and have pics?
Old Feb 25, 2006 | 09:59 PM
sgt0704's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
Axle/Gears: what ever stock is
F*ck it. it looks pretty sick. i wonder if you went with a ram air hood, if that would fix some of your clearance issues. i would agree with the fog light removal though, and put in a billet grille or something to the like there.. very sexy
Old Feb 25, 2006 | 11:06 PM
WD92TA's Avatar
From: Pensacola NAS, Florida: Hometown Valparaiso, Indiana
Car: 1992 Trans Am
Engine: 305 TBI
You could box in the fog light holes so you could capture as much air as possible. Sort of a Ram Air.
Old Feb 26, 2006 | 09:41 AM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
The only thing throwing me off is it's not centered.. The TB to CAI duct angles and the two down tubes are off center through the holes.
Kevin D.
Old Feb 26, 2006 | 09:49 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
I like it. New and original. Now chrome it!
Old Feb 26, 2006 | 09:53 AM
BT283's Avatar
someone needs to make a new thread on custom cold air intakes, i found (when searching for one for my 93 Z) that most aftermarket ones are around $200 and they dont look nearly as cool as most custom ones made for around $100
Old Feb 26, 2006 | 01:11 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
That would restrict a lot of air from the radiator. Maybe some mesh inserts instead of fog lights would be of interest to you. Also, some ceramic coating would definitely clean up the looks of that thing, and help keep the air inside cool from engine temps.
Old Feb 26, 2006 | 02:37 PM
usamuscle892's Avatar
Car: 1992 Z03 RS
Engine: (L03) 305TBI
Transmission: TH-700R4
Axle/Gears: bone stock
I think It will look fine if you polish it or paint it. I'd go with painting it a high gloss of the color of the car cuz polishing it would be more of a hassle. Looks good to me, and I too like the innovativeness (is that a word?) being used instead of the same old same old. Yank those fog lights and get a billet grill to clean up the front.
Old Feb 26, 2006 | 09:19 PM
CaysE's Avatar
Originality is great. It would look a ton better if it was polished or chromed. My only gripe... you probably lost some air flow through the radiator by removing the upper air dam. That plastic piece isn't just a tool tray, you know.
Old Feb 27, 2006 | 02:01 AM
Car: 1987 IROC
car still runs cool got my 2 fans hard wired. so no worries on that plus might be upgrading fans soon..
im very anti chrome
Old Feb 27, 2006 | 08:10 AM
BT283's Avatar
If you upgrade fans go with Spal dual 11" fans
Old Feb 28, 2006 | 09:35 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
how tacky is that? sick
Old Feb 28, 2006 | 10:18 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
the panties or the dollar?
Old Feb 28, 2006 | 11:19 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
what if ya used oval crossection pipe or kinda flatened some normap pipe some how to let it clear a bit more and then make a plate to cover the spot that the old air cleaner setup was.
Old Mar 1, 2006 | 02:11 AM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
different, but from a flow perspective, terrible. i built mine out of 3 1/2 in pipe.
Old Mar 1, 2006 | 09:46 PM
brutalform's Avatar
I know someone who has THEIR mind in the gutter!
Old Mar 12, 2006 | 12:14 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Yeah, it is different. It looks OK. Tell your exhaust guy that he forgot to put a muffler on it.
Old Mar 12, 2006 | 12:18 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Those kind of panties are reserved for blown/boosted vehicles only. It is OK to put some of lace "boy shorts" on N/A engine duct work.
Old Mar 12, 2006 | 12:19 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
it won't be bad once you get it painted,chromed, or polished. And you get the hood cleaned up. The stock airbox just doesn't allow enough airflow. My 305 feels a major difference when i made one that went from the maf down underneath the fender. Big difference there. hey if you decide to get rid of those fog lights let me know. attempting to put my car back to stock and not having any luck
Old Mar 12, 2006 | 12:22 AM
junkcltr's Avatar
Engine: 3xx ci tubo
On average, you get a 1% HP increase for every 10* F drop in intake temperatures. It is a lot more than most people realize.
Old Mar 12, 2006 | 04:07 AM
83 Crossfire TA's Avatar
But it’s not DIY, he paid someone to do it.
I’m with Lotech, a single, simple setup in the fender would have worked as well without the butchery, but even more so, what was wrong with the stock TPI type setup?
And while I’m at it, do you plan on running hood pins or something now? You’ve managed to cut out the supports around most of the latch assembly in the hood, you’re just asking for that thing to rip out, blow open and go through your windshield…
Old Mar 12, 2006 | 02:43 PM
brutalform's Avatar
Here is the route I took. I finally got the tubes powdercoated, so it looks alot better than it did.
Old Mar 12, 2006 | 02:46 PM
  #42
brutalform's Avatar
And where it passes through the fenderwell.
Old Mar 12, 2006 | 03:06 PM
  #43
brutalform's Avatar
One more. There is a large K&N filter below, and if I get a chance to take a pic, I will.
Old Mar 12, 2006 | 03:27 PM
  #44
What's on the other side of that plate where it mounts to the battery tray? I've been trying to figure out how big a filter I could fit if I cut out the whole bottom of the tray, built a box roughly the size of SLP's cold air box with no bottom and fit a filter in it all the way through the tray taking up as much room as there is in there.
Old Mar 12, 2006 | 03:59 PM
  #45
brutalform's Avatar
That plate is aluminum, and it has a 4" hole drilled through it. Then, get a piece of 4" rolled aluminum tubing, about eight inches in length. Place it halfway through the plate, and just spot weld it in a few places. This way, you will have a mounting place for the K&N filter underneath, as well as a mounting place for the dryer ducting as well. Just remove all the charcol canister junk, and you can mount it there. IIRC, I used either a 4.5, or 5 inch hole saw to cut through the sheetmetal. Then a couple of nuts, bolts and washers, and your done. Firebirds got a bad intake from the factory, so I had to make this one up. The filter is pretty large, and everything is pretty sturdy too. This wont work if you plan on keeping the canister, as this did not matter to me.
Old Mar 12, 2006 | 04:14 PM
  #46
brutalform's Avatar
I went out to the garage, and took a pic to show you what I mean. I measured the tube that goes through the plate, and it is four inches long, not eight.
Old Mar 12, 2006 | 05:02 PM
  #47
Lo-tec's Avatar
Brutalform, that setup is sweet (and the right way to do it without a cleaver), and I say that during the brief period that my mind is actually out of the gutter!!
I did my old setup very similar, except I used marine exhaust pipe (that tough rubber shee-ite with an inner steel core).
Old Mar 12, 2006 | 05:08 PM
  #48
brutalform's Avatar
Thanks Lo-tec. If you look at the right of the pic, you can see where there was an existing hole I had cut,(cleaver), on a previous attempt to fab up a CAI. With that first hole, the filter was too close to a "corner" under the car, and made it hard to fit a large filter.
Old Mar 12, 2006 | 05:26 PM
  #49
Looks really good... any idea how long that filter actually is?
Old Mar 12, 2006 | 06:01 PM
  #50
brutalform's Avatar
I'll say a minimum of eight inches long. I wanted to stuff the largest one I could under there, and have the open rubber end physically fit on the tube as well. I went to the local speed shop, and had my buddy there order about four different ones, and I took the one that was best suited.
