TPI throttle body shaft mods
Had my throttle body modded in the fall along with new bushings, the TB works OK being flowed at 785cfm with no boring. Problem is the throttle is sticky just off idle and I have to lube it once in awhile- this really bugs me. Any body here machined in a pair of sealed bearings for the shafts of a TPI/LT1 TB?
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
TB Sticking
What I did on my old 48mm was to adjust the TB screw,
under cap: And open it up just slightly. Iac should compensate for that.
Worked for me
Might also check to see if the blades are centered.
HTH
Later
Worked for me
HTH
Later
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
When the TB is completely closed, it creates a vaccuum, sucking the blades tight against the bore. Cracking open the idle stop screw should help, as long as the IAC has enough movement to compensate for it. Some folks also drill small holes in the blades...
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
I lubed up my throttle and tran and cruise cables helpped a little bit, before all that i was always hitting it to hard and chrip tires once in a while
Car: 1988 Trans AM GTA
Axle/Gears: 9-Bolt 3.27
Re: TPI throttle body shaft mods
Sorry reviving old thread. Today I dismantled my tpi throttle body by grinding the shaft on the throttle lever side. I dismantled it to take it for powder coating.
My plan was to thread the shaft to hold the throttle lever with a screw however when I removed it I realised how small the shaft diameter is. I don't imagine braising is an option as it would melt the plastic spring holder.
What are my options? I am sure someone must have a work around to this as I see people re bushing the shaft
mdtoren
Aug 16, 2015 05:45 PM
