Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Cutting timing tab for CompCams 3 piece cover
Old Apr 23, 2006 | 03:28 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I used the CompCams Aluminum 3 piece timing cover. The thing that they do not tell you until you get the directions is you can not use a regular timing tab. This is due to the spacing increase from the cover.
I started with the Jeg's aluminum pointer.
I first tried just grinding down the backside to get it to fit. Then I noticed I had to take way to much off, so I used a hacksaw to cut it down then even'd out the sides on the bench grinder. I still had to clearance one spot on the backside for the cover design. This is it done though.
Old Apr 25, 2006 | 12:17 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I was thinking of doing some thing similar with Summits 2 piece timing cover and aluminum timing tabs. I called and asked if they worked together but I was told no pointers would work with the aftermarket covers like this. WTF are you supposed to do for timing if nothing works! Anyway thats cool that you did that. Do you also have some pictures of it on the engine? or mocked up together?
Old Apr 25, 2006 | 12:21 PM
Engine: 383 SBC
Yeah, I can take some shots for you. LOL, I didn't even bother cleaning it... just threw it on there.
You might have clearance problems on the brackets, I did. The cover hit off the brackets on the serpentine belt system. I had to take a bench grinder to some of the lips and corners on the brackets to make enough room.
Old Apr 25, 2006 | 12:24 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Thats good to know too, thanks! I was going to have my brackets powder coated so I want to take care of the interference problems before I do. Look forward to the pics
Old Apr 25, 2006 | 12:28 PM
Engine: 383 SBC
That higher grinding was for my Stewart Stage 2 Aluminum water pump only I believe.
I had to take a good size notch out of the bracket for pointer clearance too. I don't have any pics of that though. I'll try to snap those here in the next few days and get them up.
Old Apr 25, 2006 | 12:31 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Thats interesting that you had to clearance the pump. I have the same one and I dont have any fitment issues.
Old Apr 25, 2006 | 12:39 PM
Engine: 383 SBC
I dunno. I was using a pre '80 truck 4-bolt so maybe that has slightly different mounts on it.
Old Apr 25, 2006 | 10:46 PM
Engine: 383 SBC
Old Apr 26, 2006 | 02:33 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
That looks pretty good. I think I will have to try that when I get the cover for myself. Did you have to get new bolts to hold it on, or were they long enough since you ground off the back tabs?
Old Apr 26, 2006 | 02:56 PM
Engine: 383 SBC
I used the bolts that came with the timing pointer. I also put loctite on everything for peace of mind.
Old Apr 26, 2006 | 06:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I don't know about the 3 piece cover, but the 2 piece Comp cover has a timing pointer now.
Old Apr 26, 2006 | 07:14 PM
Engine: 383 SBC
They might have updated there designs then. Mine is 2 years old or so.
Old Apr 26, 2006 | 07:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yeah it's a revised design. According to the catalog the 3 piece cover still has no tab.
Old Apr 26, 2006 | 07:25 PM
Engine: 383 SBC
LOL, nice. Who needs a timing tab anyways...
Old May 16, 2006 | 12:35 PM
PonyKiller87's Avatar
Car: 87 Iroc Z28
Engine: 355 TPI
Damn I had this same problem about 2 years ago, I ended up taking the regular cheepo bolt on tab and cutting about 1" out of it and welding it back together. It looks like hell and its probably not that accurate.
I guess I will be calling the local Comp rep to get me a tab.
Old May 16, 2006 | 12:44 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
That is a Jegs tab.......
Old May 16, 2006 | 12:46 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I used an adjustable tab, snipped the "teeth" off the "comb", and drilled a couple of new holes to re-mount the pointer.
1992 Trans Am
May 10, 2023 07:19 PM
Jeremys87
Jul 14, 2022 09:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
MY87LT
Aug 17, 2015 08:43 AM
