Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Homemade driveshaft loop (pics)
Old Sep 3, 2006 | 10:53 AM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
Axle/Gears: Moser M9/5:14 ratio/Billet Locker
It was a real tight fit. What do you think?
Old Sep 3, 2006 | 11:18 AM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
How much for shipping to 08742? Absoluty awsome...
Old Sep 3, 2006 | 11:27 AM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
I wish I had made more to sell! This design would work for any combo using that factory crossmember piece.
Hopefully I'll never need to use it though!
Old Sep 3, 2006 | 01:29 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
Very nice but I would suggest adding an addition brace/bolt to the rear of this piece and connect it to the floor board. If your driveshaft does happen to come apart this looks like it would bounce at the rear of the loop because it isn't bolted/braced to anything. Just a thought.
Looks Great!
Old Sep 3, 2006 | 02:20 PM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
I found a loop similar to the one I made. This loop is only held on by the bolts that go into the tranns mount! I believe mine will be stronger. I used solid steel bar, and welded the loop to the crossmember piece. Plus it only cost me my time to build!
Spohn Performance, Inc.
Old Sep 3, 2006 | 03:55 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
That's fine. I just remember seeing the ones that tie into the "frames/connectors" and bolt to the floor pan area.
Old Sep 6, 2006 | 04:39 AM
83 Crossfire TA's Avatar
Looks good…
Where did you get the actual loop part?
I’ve wondered about those designs… from the rules the implication is that 2x1/4” is the smallest profile that is strong enough to hold (their alternative tube ends up a similar cross section), but the part that the arm is welded to has much smaller area then that…
Old Sep 6, 2006 | 04:59 PM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
I didn't follow any rule book, this is only for the "In case **** happens" sort of thing.
I cut the loop at work. A found a 5 foot long section of tube, and cut it to length on the bandsaw.
You could bend one out of flat bar stock.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
topteam54
Oct 6, 2015 12:21 AM
89newfun
Sep 16, 2015 09:28 AM
Nick McCardle
Sep 10, 2015 08:36 PM
