Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
cold air intake
Old Nov 6, 2006 | 01:36 PM
pairtoe's Avatar
cold air intake
im not sure if this is the right thread but, i want to try and make a home made cold air intake, and save alot of money. my car has a mass air flow sensor, so i dont konw how to get around that and i want ti to look like the ram air intakes like on the "ram jets".
Old Nov 6, 2006 | 04:46 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
That filter on the end of that is the total opposite of cold air.
Old Nov 6, 2006 | 07:42 PM
pairtoe's Avatar
well i just want it to look like that.
Old Nov 6, 2006 | 08:35 PM
Tony89GTA's Avatar
Car: 89 GTA
Convert your computer over to speed density (90-92) and buy that filter, I believe K&N sells it.
Old Nov 6, 2006 | 08:54 PM
pairtoe's Avatar
how do you do that?
i really dont know to much about computer controled cars.
all that electronic stuffs is waaaay above my head
Old Nov 6, 2006 | 10:07 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Originally Posted by pairtoe87
how do you do that?
Well then throw the idea of converting to SD out the window.
Basically if you want that setup, its going to look goofy with the MAF setup...the whole thing will be sticking off the throttle body like 8", and plus, you'll lose power from sucking in hot engine air, compared to if you did a real cold air induction system.
Old Nov 6, 2006 | 11:28 PM
Brettlinetta's Avatar
Car: 85' Berlinetta
Engine: Twin Turbo 350 coming soon
Transmission: TH350
Axle/Gears: 10 bolt 3.42 posi
the basic dual snorkel style air induction that goes on the 2.8 TPI engine is a good start, you could just make your own dual snorkel that will flow more and pull air from down below the engine closer to the ground.. the picture you showed is all show and no go. Ditch that worthless joint and go with high flow
-Brett
Old Nov 7, 2006 | 10:13 AM
pairtoe's Avatar
so then, what would be the best way to make a home made cold air kit for performance aspect?
Old Nov 7, 2006 | 03:17 PM
Tony89GTA's Avatar
Car: 89 GTA
G0d damnit I'am trying to have some fun with the new guy
No really if you really looking to make this cold air intake there are some pretty good ideas floating around just have to do a and pick the one you like.
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
