Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
use a 2.8 performance fiero TB on camaro 2.8 3.1
Old Nov 19, 2006 | 02:00 PM
8928cam's Avatar
Car: 83 CaMarO Z28
Engine: 383 stroker AFR heads 600hp
Transmission: 700r4 stage 3
Axle/Gears: 373 9"
this same set up fiero makes a performance TB but it is highly exspensive
Attached Thumbnails use a 2.8 performance fiero TB on camaro 2.8 3.1-fiero-throttle.jpg
Old Nov 20, 2006 | 12:05 PM
Pocket's Avatar
Car: 91 Trans Am
Go look at a 2.8 Fiero TB and compare it to the Fbody TB
Its slightly larger diameter and flipped upside down
Thats all
Old Nov 20, 2006 | 01:42 PM
8928cam's Avatar
Car: 83 CaMarO Z28
Axle/Gears: 373 9"
this isnt a stock tb its the performance tb for it its larger diam.. this would be nice with the 2.8 Tb spacer the bolt match up is same as pontiac firebird i checked from junk yard 2.8 feiro
Old Nov 21, 2006 | 01:10 PM
Pocket's Avatar
Car: 91 Trans Am
Hope youve got a motor that actually needs the bigger TB
I like seriously built 2.8's and am interested in what youve got
Old Nov 22, 2006 | 02:10 PM
daves12secV6's Avatar
there is absolutly no need for a larger tb on a 2.8,the tb outflows the intake and heads,so putting on a larger tb will do nothing for u.unless u get that 2.8 up over 250 hp n/a the stock tb is more then enough
Old Dec 10, 2006 | 07:39 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Well the stock fiero throttle body says "holley" on it so thats kinda cool.
Vintageracer
Jan 10, 2020 05:33 PM
fcorallo
Aug 20, 2015 11:28 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
the_nikfive
Aug 11, 2015 02:46 AM
guy76767
Aug 6, 2015 05:58 PM
