Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
looking for info on boring out the inside of a dist. gear....
Old Dec 21, 2006 | 08:47 AM
BOTTLEDZ28's Avatar
Transmission: A4
I need to buy a composite polymer dist gear for a stock GM distributor to get my car moving around throughout the winter. The problem is that I have a MSD pro billet dist. that is getting fixed but its gonna take a little while. How hard is it to bore out the inside of the gear from.491 to .500. That is the difference between the 2 dist shafts. I am not buying 2 different size gear. They are $110 a piece.
Old Dec 21, 2006 | 10:48 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Why do you need a polymer gear?
Old Dec 21, 2006 | 10:51 AM
BOTTLEDZ28's Avatar
Transmission: A4
I am running a Comp cams billet cam and they instructed me that I need to use either a bronze gear or a polymer gear for things to work correctly. I have been running a bronze gear in the past but they get eaten up way to fast. I just installed a new bronze gear on my dizzy and have decided not to run it and get the polymer gear.
Old Dec 21, 2006 | 11:43 AM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
I just put mine in the mill at work and machined it with a .501 reamer. It has worked great. Any machine shop should be able to machine it.
The bronze one will work too if you set the gear height up just right and cut an oiling hole to lube the gear. I had a motor that got over 40k with a bronze gear. When I sold the motor it was hardly worn.
Old Dec 21, 2006 | 11:48 AM
BOTTLEDZ28's Avatar
Transmission: A4
Comp, thanks for the input. Right now, im not about to modify the dzzy. I want to set it and forget so Im just gonna order anew polymer gear for a stock dizzy and then swap it over to my MSD dizzy once it gets repaired.
Old Dec 21, 2006 | 12:27 PM
Comp788's Avatar
I have seen people just drill them out with a 1/2" bit but it is important for them to be on center. IMO I do not think a drill bit is the way to do it. I am sure it probably "works" but I am not into hacking stuff. Machining it on ceter is the way to go, if you want to do it right.
Old Dec 22, 2006 | 03:39 PM
Dan W's Avatar
Aren't the stock roller cams billet? I ask because they don't run a bronze or polymer gear.
Old Dec 22, 2006 | 05:07 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I would just chuck it up on the old lath and cut inside hole as needed.
pjsparts
Oct 29, 2025 06:39 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
deemoney
Theoretical and Street Racing
Sep 13, 2015 07:02 PM
Mr. Chevy
Sep 11, 2015 06:06 PM
89-S-dime
Southern California Area
Sep 4, 2015 10:34 AM
