Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
3RDGen Stuck in a rut?
Old Jan 18, 2007 | 10:03 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
3RDGen Stuck in a rut? Once ya get holes dug best way is to just jack it up and get something under the tires. 2x4 works good but don't always provide traction and you can slip off them.
[every year I get the Firebird stuck in my own yard around this time, to many cars not enough drive way width...]
Worked great, better the my last design.
Which was 3-4 pieces of sign post welded into a \_/\_/\_/\_/ shape and on the _ spot where the sign post is full of holes. I put lose double nutted bolts. So once on there when the tire spins it grabbed and pull on the lose bolts.
But they didn't work well with boards n stuff or soft mud when they sank, also spit our easier.
Newer idea works much better as it hold on to the board tight [not nailed down or n e thing] so it doesn't spit out or slip off. Though both work fine if its just ice or snow.
I find most times ya only need to get out of your rut to get movin
tmellott89
Oct 14, 2015 02:06 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
HikoriYami
Sep 21, 2015 07:11 PM
steimel94
Sep 20, 2015 12:46 PM
ctoledo0834
Sep 18, 2015 04:16 PM
