Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
The Future in Cold Air Induction!!
Old Mar 10, 2007 | 01:36 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
check out this space-age technology!!
this has probably been here before, but i just found it the other day and laughed my *** off, maybe peed a little too...
Old Mar 10, 2007 | 05:43 PM
mourningyou's Avatar
He fears NO puddles.
Old Mar 10, 2007 | 06:11 PM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
Now thats a real t-top
Old Mar 10, 2007 | 07:00 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Gonna suck if he gets caught in a sudden shower
Old Mar 10, 2007 | 07:42 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Old Mar 10, 2007 | 10:37 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Sort of a rear cowl induction setup.
Old Mar 10, 2007 | 10:42 PM
Bazookajoe254's Avatar
Car: 86 Firebird
Engine: 2.8 V6
I wonder what the little tube going into the window is for..?
I wanna see someone run some dryer duct from their AC vents into the throttle body.
Old Mar 11, 2007 | 09:44 AM
Vader's Avatar
LMAO! I like the "cold air inlet" quarter glass, too! That "thing" going through the side window might be the string holding the filter to the roof. Those Honda boys get all the cool stuff.
Old Mar 11, 2007 | 12:16 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i figured the "string" was to hold the thing to the roof, so i guess you cant open the windows or it will fly away
Old Mar 13, 2007 | 07:06 PM
Stephen's Avatar
Car: 87 GTA
I've actually wondered about that...
I'm know the AC blower motor can't supply 100% of the air an engine needed, but could it supply enough, if it was merged with a normal intake, to help reduce the incoming air temp, the engine is seeing? Getting it before the IAT sensor of course, for those of us who longer have it mounted under the bottom of the HOT aluminum plenum. How much hp does the AC REALLY use? 5hp? 20hp? Could it be of benefit, to offset the power drain?
Just like, since the AC condenser line gets cold enough to form condensation, could your fuel line be wrapped around it, to be of any benefit?
I know several people will get a laugh out of these ideas, but so are airfoils. They are only worth what? 2hp? But, people have them.
Old Mar 13, 2007 | 07:12 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
why bother with a little ac blower when you could strap a gas leaf blower to the thing
Old Mar 13, 2007 | 07:24 PM
Stephen's Avatar
Car: 87 GTA
I was more or less meaning the temp drop.
Hmmm...Leaf blower, plumbed into the fuel line, using the AC system as a air souce. More pressure, lower temps.
but, if it works, it works. People spend a crap-load of $, to get 10 hp gains, from "proven" aftermarket parts. Headers aren't worth a WHOLE lot, but people spend $400+ all day on those.
It is the little things that add up in the end.
Old Mar 13, 2007 | 08:49 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Maybe it's to make sure it don't fall off
Old Mar 13, 2007 | 09:34 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Leaf blower, I love it................14's here I come.........................Well seriously, if it werent for people having wild ideas like that we would never get nothing new.........hmmm leaf blower.......14's here I come, oh hell I am repeating myself.......LOL.......
Old Mar 13, 2007 | 10:45 PM
birdsgonnafly's Avatar
Car: 87 T/A
Engine: none right now
Transmission: prob th350
http://videos.streetfire.net/search/...ad23ca9564.htm
watch the whole thing LMFAO
Old Mar 13, 2007 | 11:09 PM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
I always wondered how Icebox intakes would work for bigger engined V8 domestic cars.
Old Mar 14, 2007 | 01:14 PM
StreetRod's Avatar
Car: 89 Supra
Engine: Tbi 350
That video is to funny!
Old Mar 14, 2007 | 01:22 PM
Stephen's Avatar
Car: 87 GTA
Sad part is, TBIs were lucky to hit 14s, and most TPIs were in the 14s, OCCASIONALY in the high 13s, but that was typically good luck.
Nowm if they are hitting the same numbers, with HALF the cylinders...
Old Mar 14, 2007 | 08:26 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I actually think you might have something going there. I agree, though, about how cold the temperature of the air would be once it reaches the spark plug, also, what about the oxygen content? Hhmm, Interesting but I don't think I would want to give up my A/C, specially here in the South!!!
Old Mar 14, 2007 | 09:03 PM
Stephen's Avatar
Car: 87 GTA
South Carolina isn't the south... ...Central Texas (where I am, is south! )
I guess I could find a thermometer, to measure the temp of my AC. The question is, would it REALLY be of benefit?
As far as giving up your AC, maybe the ducting could have a control valve. Off, its normal AC, on, it is directed to the engine? In any case, it would at least lower the incoming temp of the air. I know my GTA has a noticeable increase in hp, during 40 degree weather (about as cold as it gets here regularly) as compared to the 100+ degree days during Summer.
Old Mar 14, 2007 | 09:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Originally Posted by birdsgonnafly
holy sh#t i cant stop laughing!!
Old Mar 14, 2007 | 10:17 PM
HCR13's Avatar
Car: 1987 Trans Am
That is true. Like I said the only problem is making sure that air stays cold until combustion, liquid oxygen anyone?
Old Mar 14, 2007 | 11:21 PM
Car: 87 T/A
The song just pushes it over the edge of gayness ops I meant greatness
Old Mar 14, 2007 | 11:56 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I guess as far as 'high rise intakes' go, he wins?
Old Mar 15, 2007 | 12:07 AM
ws6gta89's Avatar
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
I have thought about making a cold air set-up that is a tube that runs through a a compartment that has a cap that could be taken off so that i could put dry ice in it so that it would cool the pipe itself and hopefully the incoming air also and that compartment would not allow that fumes from that dry ice to get in the motor
Old Mar 15, 2007 | 09:56 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
I wonder where the guy that holds the leaf blower is during a run at the track?
Old Mar 15, 2007 | 08:51 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
and to help harness all that new-found power
need I say more...
Old Mar 15, 2007 | 11:34 PM
HCR13's Avatar
Car: 1987 Trans Am
^That is insane!
Old Mar 16, 2007 | 09:32 AM
Car: 87 T/A
He need all that wing for when v-tak hits
Old Mar 16, 2007 | 09:45 AM
Giovannetti's Avatar
lmao nice fella's
Old Apr 15, 2007 | 10:07 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
Re: The Future in Cold Air Induction!!
hahaha i never thought that would actually work, just figured it would bog from way too much air.
Old Apr 15, 2007 | 10:29 PM
Stephen's Avatar
Car: 87 GTA
Nah...An SBC needs more air than a leaf blower can provide alone.
Dry Ice vapor is NOT combustible. Basically, you'd be starving your engine of O2, nothing else. Nothing actually harmful, at least.
"If the kids place a lit candle on the table, they can then "pour" the CO2 gas from their styrofoam cup onto the flame. It should go out. This is evidence that you have a gas, heavier than air, and that it is a gas which does not provide oxygen for combustion. CO2 fire extinguishers are quite common."
Old Apr 16, 2007 | 03:12 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Transmission: manual
my buddies and i actually tried the leaf blower set up on his 90something shadow 3.0 in a walmart parking lot...we ziptied it under the hood the the radiator mounts or i dont remember and drove it around the parking lot, didnt work and i finally know why..it was just blowing hot air cuz of the low speeds and no incoming air to the leaf blower. maybe we can do it again with alittle ram air!!??
Old Apr 16, 2007 | 06:54 PM
johnnyboy's Avatar
a friend and i were trying to figure out a novel way to make a cold air system like coiling a pipe around the intake tubing that runs nitrogen through it to cool the incoming air, but that just wouldn't be safe under the hood of a car . at least as far as i know . or running an intercooler with the cryo system that sprays the co2 onto the intercooler to cool the air, but without any kind of a supercharger or turbocharger. but then that would just be a waste, if you have an intercooler why not add a supercharger or turbo.
Old Apr 22, 2007 | 03:37 AM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
No the pipe would run through a compartment that had the dry ice in it in an attemt to cool down the pipe and incoming air but not get the crap from the ice
Old Apr 24, 2007 | 02:37 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
http://www.wesellcarparts.com/store/...idproduct=2305
Old Apr 24, 2007 | 02:51 PM
Stephen's Avatar
Car: 87 GTA
Nice.... "Air Intake Blower produces 250CFM of forced air into your intake." Maybe with 3 of them, I can achieve the stock amount of intake my car needs...
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
jimmy harris
Aug 31, 2015 03:09 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
