Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Water Jet Service ???
Old Mar 13, 2007 | 08:05 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Can anyone recommend a company that uses water jet to make a custom switch panel for me?
I haven't had any luck, the one I found hasnt' returned my email.
thanks,
Rafael
Old Mar 13, 2007 | 09:53 AM
fbodyguy86's Avatar
Car: 92 camaro rs
i had a friend of mine make me one for my camaro that mounts in the ashtray made it our of diamond plate aluminum if you take your time it will look great
Old Mar 13, 2007 | 10:14 AM
luvofjah's Avatar
I'm legally blind, I would prefer to pay someone to do it right since I don't see so well...
Raf
Old Mar 13, 2007 | 12:37 PM
madmatt92RS's Avatar
Car: 92 Camaro RS 25th aniversary editio
Engine: 305 tbi
Transmission: auto
you could also find someone with a laser to cut it out. lasers can cut about anything that a water jet can. as long as it doesn't give of harmful gases when heated. also as long as you're not wanting it out of something thin and alot cut out of it because that can cause warping
Old Mar 13, 2007 | 01:15 PM
luvofjah's Avatar
That's why I posted... to find someone... water, laser, rock, whatever...
Please name a few places you have dealt with that do this kind of work.. I can't seem to find anyone to take my money...
Raf
Old Mar 13, 2007 | 01:44 PM
Pocket's Avatar
Car: 91 Trans Am
http://www.emachineshop.com/index.htm
Found that one either some fbody site or the FSAE site i cant remember
I have not had any dealings with them and cant vouch either way
Food for thought
Old Mar 13, 2007 | 02:07 PM
luvofjah's Avatar
Yup, they want about $200 for the piece I want..
I heard water jet was cheaper...
Raf
Old Mar 13, 2007 | 02:20 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Try using ThomasNet (formerly Thomas Register). I used them to find the laser-cut vendor I use.
http://www.thomasnet.com
Lon
Old Mar 13, 2007 | 03:43 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
There is a place in Kenosha, WI that I used recently for custom regulator/nitrous solenoid mount. You can see the end product in the PowerAdder forum. I paid 180ish for 5 pieces to be cut. They charge you the material and labor time. I thought the labor time was pretty cheap since other shops wanted to charge me 150+/hr. The only thing that I didn't like was that it was almost a month-and-a-half until they finished the parts. It was my fault though since I wasn't pressed for time and told them so. The place is called Ultra-Fab.
http://www.ultra-fabinc.com/index.html
Old Mar 13, 2007 | 06:55 PM
Stephen's Avatar
Car: 87 GTA
DC Electronic Industries, Inc.
1509 Brandi Lane, P.O. Box 1657
Round Rock, TX 78680
Phone: 512-244-1508
Fax: 512-244-1579
ThomasJet profile
Doing signs, ranging from vinyl for windows, to building signs, neon lettering, post signs, etc., this was the place we used for water jet cutting. Great work! I have no idea on their pricing, but knowing the owner of our company, they were very reasonable, and their work was always top-notch when I picked it up. Great place & people to deal with too!
Old Mar 14, 2007 | 09:13 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
FYI the laser will not warp something thin as when it cuts it does not induce much heat. Water Jet machines typically cut thicker material then laser jet machines. I know because we have a laser at work. Our machine is a 4000 watt machine and it will cut up to 7/8" steel and 5/8" stainless. We only cut stainless steel on our machine.
A similar size water Jet machine would cut 2" thick steel and 1 1/2" thick stainless.
Old Mar 14, 2007 | 09:22 PM
Stephen's Avatar
Car: 87 GTA
But...As the material gets thicker, the jet itself veers off, depending on the strength of the water jet machine. At the place I used to work at, it was used to cut glass circles, but the glass had to be miced for tolerance afterwards, for a pass or fail.
Old Mar 14, 2007 | 09:38 PM
Comp788's Avatar
Stephen,
That happens with every type of cutting from Laser Jet, Water Jet, Hi Deff Plasma, regular Plasma, and flame cutting. It is called Curf.
As the material gets thicker the Laser beam, water jet, Plasma arc, or flame cut diverts as it gets to the bottom of the material. That is why you use a different focal point or cut point to keep the Curf to a minimum.
As a rule of thumb for a laser it is .001 per 1/16" of an inch.
Old Mar 14, 2007 | 09:41 PM
Stephen's Avatar
Car: 87 GTA
I've done plasma too, but with the stuff we did, thickness wasn't an issue.
Old Mar 17, 2007 | 11:43 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
what exactally are you looking to do? I could prob do it outa 6061 T6 alum. in a cnc.
sheachopper
Jul 31, 2019 11:27 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
