Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
custom meth injection system/aux nitrous fuel tank fab
Old Mar 13, 2007 | 08:01 PM
daves12secV6's Avatar
hers some shots of a 1/2 gallon tank i made for a diy meth injection system.
its an all aluminum tank.mounted inside the tank on a removable hanger/flange is a hi press walborow intank pump. this could be used for a diy meth injection,and or as an aux tank/pump for a wet nitrous system.
were the pump is mounted there will be an -6 an fitting ontop of the tank for the pressure line,and another on the top side of the tank for a return line.
in the one pic u can see the bulkhead electrical conectors ill be using to get the power to the pump.
PS THE ZIP TIES ARE JUST TEMPORARY TILL I GET THE ACTUAL PUMP MOUNT FINISHED
the round flange thats ontop of the pump hanger gets drilled and taped so it can be bolted down to the top of the tank with a gasket so it dosent leak
Old Mar 15, 2007 | 09:20 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
thats cool. gotta love bein able to fab up whar ever you want..
Old Mar 15, 2007 | 10:24 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Yea, nice piece. Looks like you put a lil time into that!
midge54
Dec 27, 2019 04:14 PM
mustangman65_79
Apr 14, 2017 05:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
86Base
Aug 13, 2015 05:06 PM
