Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
rod ends
Old Mar 13, 2007 | 09:03 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
Axle/Gears: ford 9in 4:56 to 1
rod ends
what size rod ends is everyone using to make their trailing arms and panhard rods?
Old Mar 14, 2007 | 07:26 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
I used 3/4" rod ends with a step down spacer to 1/2". You will need to enlarge the mounting holes a tiny bit to get a 1/2" bolt through, or you could just hammer the snot out of them. 1/2 is very close to stock just a tad bigger.
Old Mar 14, 2007 | 09:07 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
I used 3/4" fine x 5/8" 4130 Aurora rod ends with a spacer neck it down to 1/2"
As for tubing I used 1 1/4" x .095 4130 tubing.
I had to slightly drill out the mounting holes too.
Old Mar 14, 2007 | 09:59 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
pics ?
i cant imagine how you could use rod ends on trailing arms and control arms
im confused
thanks
Old Mar 15, 2007 | 11:38 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Many aftermarket manufacturers, like Spohn, make them. I made some homebuilt ones that were posted a couple weeks ago in the suspension forum. They are very popular, moreso with the drag crowd that the street crowd.
Old Mar 16, 2007 | 12:29 AM
Comp788's Avatar
Originally Posted by Randy82WS7
pics ?
im confused
thanks
Randy, I'll try and get up a couple of pictures this weekend. In this link to another thread you can see a few people who have built them this way.
https://www.thirdgen.org/forums/susp...-finished.html
mantaguy
Sep 1, 2015 08:39 PM
gixxer92
Sep 1, 2015 04:32 PM
Thaney9
Aug 29, 2015 03:16 PM
zayne0
Aug 24, 2015 07:22 PM
