Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Sub frame connectors, bolt on or welded?
Old Mar 22, 2007 | 01:12 PM
bolandmi's Avatar
So I know first off, if I were to purchase bolt on subframe connectors, I know that there will be that pain of tightening the bolts from time to time, and that sort of simple thing, but do they actually function just as strong as welded connectors?
Just want some suggestions as to if I should or should not get the bolt on, mainly because I don't have a welder and for ease of installation.
These are the ones I'm looking at: http://cgi.ebay.com/ebaymotors/82-92...spagenameZWDVW
Old Mar 22, 2007 | 02:07 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: Sub frame connectors, bolt on or welded?
I put a set of bolt ons from TDS and am very happy with the way they fit. They don't run along the sides and have saddles that fit around the end of the subframe. The TDS bolt ons will be easy to weld in due to the way they fit.
http://www.top-downsolutions.com/pro...products_id=90
Old Mar 26, 2007 | 05:45 PM
Stephen's Avatar
Car: 87 GTA
You can always put your bolt-ons on at home yourself, then go find someone that will weld them for you. Bolt-on doesn't mean non-weldable.
Old Mar 26, 2007 | 05:56 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
I suggest welding. PLEASE pull up your carpet though! I've seen too many Fbodies burn because of the floors get to hot and catch the carpet on fire.
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Dialed_In
Aug 20, 2015 01:45 PM
