Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Fabbing a strut tower brace and Panhard bar
Old Apr 1, 2007 | 12:54 PM
Bowtye101's Avatar
Car: 1991 RS/ 2006 Charger R/T SRT-8
Engine: 383 4bbl / 6.1 liter HEMI
Transmission: TCI 700R4
Axle/Gears: 3.42 posi
I was wondering if anyone here has specs on fabbing a strut tower brace (carb) and panhard bar. I have some 3/4" QA1 rod ends but would like some info before I start. I have a dealers (Toyota) shop to work in but have never tried to do this before. I have welding experience. What type of steel should I use? Can I use aluminum? I have a machine tool lathe at the shop but have never used one. Any help would be appreciated. Pics or schematics would be great.
Old Apr 1, 2007 | 02:07 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Fabbing a strut tower brace and Panhard bar
Try searching on here. I don't think anyone has posted schematics or drawings, most guys just do it by eye sorta thing. There are a handful of good ones done by the members.
AL would work out ok, but I think 4130 or something might be better. Those rod ends might be a tad overkill, but your call.
I forget the name of the guy who did them recently, with rubber bushings on one end, rod end on the other end. It was LCA's, made with AL. I'd do that idea on the panhard.
Old Apr 1, 2007 | 02:27 PM
Bowtye101's Avatar
I was thinking about aluminum for the strut brace, wouldn't a aluminum panhard bar twist unless it was solid? I have twisted two stock bars
Old Apr 1, 2007 | 02:33 PM
Sonix's Avatar
Car: 1982 Trans-Am
Solid? No...? Do you mean solid as in "stiff", or solid as in "no hole in the center"? No panhard bars are ever solid that i've seen.
And no, they shouldn't be twisting at all? Use rod ends, or at least on one side, that should eliminate any chance of it twisting, and let it only do it's job of absorbing tensile and compressive stress.
Might as well fab up LCA's while you're there. Rod end on one side, poly on the other side (car body side). That's the best for a hard street application IMHO.
Old Apr 1, 2007 | 11:09 PM
Stephen's Avatar
Car: 87 GTA
I saw a home-fabbed aluminum one somewhere, but apparently I didn't save the pic
My question is...Why are the STB made to pivot at the strut towers, except the old (no longer made) Kenny Brown unit? I'm thinking that style will be stronger, although it might stress the mounts more. Maybe a bigger foot print, and something that slips under the 3 bolts of the strut mount.
Old Apr 2, 2007 | 12:54 AM
Sonix's Avatar
Car: 1982 Trans-Am
I'd guess you only want to limit the compressive and tensile loads, so the rod ends do that.
You don't want to limit the shear stress sorta thing, or else it'd just have a tendancy to rip the mounts apart, or maybe cause weird handling?
Maybe you're thinking of one of these threads stephan;
https://www.thirdgen.org/forums/susp...uminum+panhard
https://www.thirdgen.org/forums/fabr...uminum+panhard
The first one was posted in the suspension board, not the fabrication board. That's why I always had a weird time finding it... That's the guy I was talking about as well.
Old Apr 2, 2007 | 01:06 AM
Stephen's Avatar
Car: 87 GTA
I did a quick look through both of those threads, and no pic of an aluminum STB. I'll look around...
Old Apr 2, 2007 | 01:34 AM
Stephen's Avatar
Car: 87 GTA
I knew if I looked hard enough, I'd find it!
https://www.thirdgen.org/forums/fabr...t-stuff-i.html
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
