Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Welding Powdercoated Subframe Connectors
Old Apr 6, 2007 | 06:32 AM
1irocz2nv's Avatar
Hey guys, dumb question here as I have no welding experience. If you have powdercoated subframe connectors, do you have to grind off the powdercoat to weld to the bare metal? It's not something that I'm attempting, just curious before I purchase my subframe connectors.
Old Apr 6, 2007 | 07:07 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: Welding Powdercoated Subframe Connectors
Yes. You need metal-metal to weld.
Old Apr 14, 2007 | 02:18 AM
83 Crossfire TA's Avatar
I usually put them up in position, mark all the spots on the body and the connectors, grind off the powdercoat and any coatings on the body, spray them with some weld through primer and then weld…
Old Apr 14, 2007 | 08:31 AM
1irocz2nv's Avatar
Thanks for you help, much appreciated.
Old Apr 15, 2007 | 06:12 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Then spray it with a rattle can after the weldig has cooled.
Lon
Old Apr 16, 2007 | 02:12 AM
Heh, if you get it just right you hit it with the spray bomb while it’s still cooling and the whole area is in the 150* range… you’ll bake the paint on and it will be almost as hard as the original powdercoat. The warm parts also cause the paint to flow out better for a smoother, shinier finish with less chance of runs…
Of course, I seem to get luckier than most
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
RS Reaper
Sep 27, 2015 07:04 PM
ccop
Convertibles
Sep 14, 2015 04:13 PM
Nick McCardle
Sep 10, 2015 08:36 PM
