Cowl hood, keeping the intake air cold....
Car: 1990 RS/SS modified
Engine: 355ci, 113 heads, LT4 hotcam
Axle/Gears: 3.73 Eaton posi
Are there any pics out there with a third gen and a Cowl hood tray under the carb? I'm looking for anything that will help me figure out how to fabricate it. I don't want the engine bay heating up the intake air.... Would it be easire to just put a sheet of aluminum on the hood, and cut a circle out for the aircleaner, or to make a tray under the carb with foam so it seals on the hood?
Opinions or ideas WELCOME....
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: Cowl hood, keeping the intake air cold....
your idea would be good.. just make sure the hole is big enough to compensate for engine torquing.. or you could just run solid motor mounts like me..
Car: '82 Z28
Here's what I did a while back. I'm running a harwood 3 inch cowl and only run that pan at the track.
Car: 1987 Trans Am
Why only at the track? Isn't the whole idea to take in cooler air from outside the engine compartment via the highpressure area at the windshield, thus resulting in higher engine efficiency? Why wouldn't you want your engine to be more efficient, thus making more power on the street also?
Evil Cartman,
Did you buy that or build it? Thats what I'm looking for...
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I run filters at the track. I cut out a piece of aluminum and attached it to the underside of the filter base. The sealing foam is inside the cowl and scoop.
Car: '82 Z28
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ElPaleterro85
Aug 13, 2015 03:49 PM
