anyone tried to chrome hood louvers
Car: 88 convertible iroc
Engine: 305 tpi
I am interested to find out if anyone has had the hood louvers chromed or can it even be done. Would it be better to have some made or maybe just use chrome paint. I am interested in doing them in black chrome if anyone cared.
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Re: anyone tried to chrome hood louvers
Black chrome...hmnnnn....I would be interested to see that..
Axle/Gears: Posi
Now that you mention it I have an old louver that will never be used because of broken studs and I have some chrome paint. I think later today I will paint it just to see. I will post pics tonight.
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
lol i didnt even know chrome paint existed
I thought it was a plating process.
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
so they invented the paint for this kinda stuff and i have never tried the paint, but ive seen a place on horsepower tv i think that can chrome anything and make it look damn good! they do shoes and everything, anyone know the place im talking about? Trending Topics
Car: 92 Z28
Engine: Boosted LSX
it is a plating process but good luck trying to plate plastic
so they invented the paint for this kinda stuff and i have never tried the paint, but ive seen a place on horsepower tv i think that can chrome anything and make it look damn good! they do shoes and everything, anyone know the place im talking about?Yep, Ive used it. Its a spray chemical so anytihng becomes platable.
If you want the closest look to chrome for something anyone at home can do.
(as long s you have a compressor, and a HVLP paint gun)
I have a Quart of this stuff Ive used before and its awesome.
http://www.alsacorp.com/products/mir...irrachrome.htm
look here for spray kan version of chrome.
http://www.alsacorp.com/products/kil...llerchrome.htm
Car: 86 Z28 & 1980 FIREBIRD
Engine: 350 & 454
Transmission: TURBO 400
I have seen a guy buy some diamond plate sheets and he traced the design and cut them out and they look damn good. and plus the chrome paint is more lke a silver anyway it looks bad. I wouldnt do that the have some paint that is metalic in every color even black in most auto paint stores. its basicly just a thin coat of black just tinting the chrome. that way you still see the chrome glare at a black look.
Chrome paints can look OK as long as you can keep them from reacting with whatever is under them, which is much more difficult than you expect after using other paints. When it reacts you tend to get a duller finish, more silvery and if it reacts badly you can get cracking, checking… to the point that the stuff almost looks like grey primer. Also, supposedly you can top coat the stuff with clear to protect it, but every time I’ve gotten a part successfully coated without reacting and looking good, coating it with clear has ruined it, again, reacting with the chrome paint and turning it dull.
Plastic can actually be chromed, you have to give it a conductive coating first, but in most cases to get that look instead of being “chromed” or painted plastic is actually vacuum metalized (essentially spraying the plastic with vaporized aluminum, plating it with aluminum rather then chrome). This is how reflectors and many shiny surfaces are made, and the advantage there is that you can pretty much do it to anything that will withstand (and fit in) the vacuum chamber which the process is done in.
Engine: 305 tpi
My thought initially was to have the louvers fiberglassed and then painted with the black chrome paint. I have seen helmets done with the chrome paint and they look pretty good. How does that sound?
Car: 1987 Firebird
Engine: 355
Type in plating into google for your local area.
It can be done to plastic. Remember the 2nd gen camaros, or earlier GM cars with the door lock studs? They were plastic, and had nice chrome layer on them. I dont think its chrome per say, but there is a specialized process for plastics. I know my old buick had alot of these parts.
Chrome paint is referring to that stuff you buy in an aerosol can. Its like a really good silver, but not chrome or even close.
In any case, id like to see the outcome of this as well.
Heres a site i found in about 30 seconds.
http://www.specialtychromedplastics.com/
Engine: 350 & 454
Car: 92 Z28
Engine: Boosted LSX
You can find tons of pic's here...
Car: 87 GTA
If plastics for scale models can be chromed, no reason the louvers can't be.
Just do a search for plastic coaters in your area, or find a metal plater in your area, and likely he'll know of a local plastic coater.
i have a friend who does custom crotch rockets.....his one show bike has plastic parts cromed on it. it looks good but all platic i have seen done does not look quite as good as metal done. but it is possible to do plastic
Engine: 350 & 454
http://www.alsacorp.com/products/kil...llerchrome.htm and
http://www.specialtychromedplastics.com/ these are some sites for chromed plastic. hope this helps.
It sounds like the parts he wants to have chromed are plastic by the content of this thread, but isn't there a chrome color powdercoat now? Or a ceramic coat perhaps? How does that come out? It seems to me that this would be cheaper. Chrome plating is notoriously expensive.
Mathius
Car: 92 Z28
Engine: Boosted LSX
Yes he wants the louvers done. Yu can powder coat plastic Ive done LSx intakes a few times.
Th eproblem is You dont know the quality plastic used on the louves and would need to see if they can take the cure temps.
The Products posted from alsa corp are gonna be your best solution to the question on how to do it.
http://www.alsacorp.com/products/mir.../mshelmet1.jpg
You know the stuff even works on fabrics.
http://www.alsacorp.com/products/mir.../DSC07685L.jpg
Now if you MUST have it REAL chrome plated you need to either find a company that does vacuume chamber plastics like modle cars. Or find someone who used...... conductive paint for real tank plating...
* Make non-conductive items conductive so that you can plate them like normal.
bonds to all plastics, materials like dried flowers, baby shoes, etc.
Tons of companies who make stuff..
http://www.thomasnet.com/products/co...6281603-1.html
I was just wondering if you had any experience with the "chrome" powdercoating/ceramic coating, and how well it came out?
Mathius
Car: 92 Z28
Engine: Boosted LSX
Yes, I do alot of the chrome powder coating looks decent. Deff. not a CHROME finish but nice. I prefer the polished / clear coated look.
I do alot of ceramic (headers,and exhaust) that comes out nice also.
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
