Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
5 pt. Harness Bar Ideas
Old Oct 29, 2007 | 11:37 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I am no longer going with a roll bar to save time and money but need something to hook my harness straps to. I was thinking about fabbing up a harness bar (similar to a strut bar) that would bolt to the stock rear over the shoulder seatbelt locations.
Ideas?
Old Oct 29, 2007 | 11:59 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: 5 pt. Harness Bar Ideas
stock seatbelts or at least a 4 point roll bar for the harness to bolt too.
Old Nov 5, 2007 | 01:32 AM
CarterCarbureto's Avatar
Car: 1987 Z28 camaro
Engine: 305 V8
Transmission: auto
Axle/Gears: 10 bolt pozi
check the other forum out:
https://www.thirdgen.org/forums/inte...ml#post3521278
I added some pics and such
Old Nov 5, 2007 | 04:25 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
It is absolutly not safe to run with a harness bar like that. That being said, I do use 4-points when I auto-x but that is just to hold me in the seat, at 30mph with nothing to hit, I doubt I will be involved in anything that would cause a problem.
IF you plan on using these on the streets, full track, drag strip, etc. PLEASE make sure you have real roll over protection. And that you follow the harness manufactures and/or sactioning body's mounting rules for mounting them. The factor 3-point belts are designed to keep you in your seat and safe, in a roll over, your head can move towards the center of the car, should the roof collaps. With 4/5/6-point harness', you head becomes the roll bar.
--John
9192camaro
16
Feb 3, 2019 12:21 AM
RedLeader289
Jan 22, 2016 03:05 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
fbirdroller
Sep 2, 2015 10:27 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
